06-16-2013, 04:17 PM | #1 |
running boards
HI: Does anybody know if 1930 Tudor running boards will fit on a late 31 Tudor????. Thanks let me know reggiedog
06-16-2013, 07:56 PM | #2 |
Re: running boards
Reggie, The running boards themsleves would fit, however the difference is in the splash aprons. If the apron was attached to the running board then you would have to set those parts up as 30 splash aprons on a 31. If somehow the running boards were separated then they would probably work with the full 1 piece splash apron on a 31. The basic running board "in shape" is the same, the mat configuration and molding is a little bit different also.
06-17-2013, 05:14 AM | #3 |
Re: running boards
