Old 04-12-2017, 06:09 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default A Minor Generator Painting Tip
When I sandblast and paint the rear end plate on the generator, I make a tapered wood plug to keep all dust and grit out of the bearing.
I found that if I use a can opener to remove the lip of the empty cocoa can, it will be a perfect fit to the locating ring on the end plate. This keeps the paint off the brush holders, and makes a good support while the paint dries.
Old 04-12-2017, 08:23 PM   #2
Larry Jenkins
Default Re: A Minor Generator Painting Tip
We need more good tips with images. Would solve a lot of Qs..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 04-12-2017, 09:46 PM   #3
SeaSlugs
SeaSlugs's Avatar
interesting, i bet a mixed nuts can would be roughly the same diameter as well.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-13-2017, 09:32 AM   #4
old31
Oh Oh. I can see me going through a lot of mixed nuts and cocoa trying to find the best generator support.
old31 is offline   Reply With Quote
Old 04-13-2017, 10:28 AM   #5
SeaSlugs
SeaSlugs's Avatar
you make it sound like thats a bad thing! Have a beer or twelve with the nuts and add some baileys to the hot cocoa and you will find out in no time
Old 04-13-2017, 11:37 AM   #6
Cool Hand Lurker
Cool Hand Lurker's Avatar
And to keep this thread 'Model A' be sure to heat the cocoa on the manifold.
I have a tough time throwing away empty cans. They always seem to come in handy for holding things like an armature with an end plate. Especially the tall juice cans. Great for soaking carb parts in too.
Cool Hand Lurker is offline   Reply With Quote
Old 04-14-2017, 02:04 AM   #7
Tom Wesenberg
I think I showed this before, but to protect the field windings while sandblasting and painting, I cut two aluminum discs that fit snug inside the case, and are held tight with a 1/4" x 4 1/2" bolt.
Old 04-14-2017, 08:53 AM   #8
Larry Jenkins
Great example of show and tell!
Where there's a will..
Old 04-14-2017, 09:58 AM   #9
Cool Hand Lurker
Good idea Tom. It seems that sand will always find a way to get in, kind of like mice. If you find that sand still gets in, you can cut a disc from a plastic bag just a little larger than the aluminum disc with a bolt hole in the middle and use it for a gasket to be sure of a seal.
Old 04-14-2017, 10:36 AM   #10
30 Tudor
30 Tudor's Avatar
Great Ideas!
I've always wanted my own blast cabinet, I'll tell the wife you've pushed me over the edge! She'll need your #
30 Tudor is offline   Reply With Quote
Old 04-14-2017, 01:39 PM   #11
Tom Wesenberg
Actually I did cut some circles out of a 1/4" thick foam pad I have, and that does the trick. I also install screws in the mounting holes for the cutout and mounting bracket to keep the sand out.
You're certainly right about the sand gets everywhere. I even wish my blast cabinet was outside instead of the basement.
Old 04-14-2017, 03:00 PM   #12
Larry Jenkins
Tape all suspect places where sand could blow through. Sticky aluminum furnace tape comes to mind..
