Old 04-11-2022, 02:01 PM   #1
56sedandelivery
56sedandelivery's Avatar
Default 56 Door retainer pin?
Do not know if I asked this or not so here goes. Getting ready to pull the doors off. There is a retainer? that keeps the door from opening too far. It is held on with a pin. I can grind it off and get it out but then what to replace it with?
56sedandelivery is offline   Reply With Quote
Old 04-11-2022, 02:24 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: 56 Door retainer pin?
You replace it with this:
https://www.ebay.com/itm/313117987961
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 04-11-2022, 03:20 PM   #3
56sedandelivery
Thanks for the link. Hopefully it will come back up for sale
Hah, actually cheaper factory direct
Now to get the pin out. Ground off the bottom part that was flared out but it is stuck good. Tried a drift punch, no go. May have to try heating it unless someone has a better option.
Old 04-11-2022, 05:08 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
When I took my doors off, I used an electric drill with a bit that was a little smaller than the diameter of the pin. I drilled the pin from the bottom upwards about 1/8 inch deep. I had to hold the top of the pin with a small pair of vice-grips while drilling so the pin would not spin around while I was trying to drill it.
After that, you can crush the last little bit of the bottom of the pin inward and pull it straight out. I used a pair of electricians pliers to crush the pin all around. Of course the pin is un-usable after that.
At the time when I was redoing my car, I bought replacement pins from one of the repro parts suppliers. The new ones are a little different, their pins are a little longer and have a retainer clip at the bottom so the pins can't fall out.
Old 04-11-2022, 06:52 PM   #5
56sedandelivery
I will have to try the drill as I ground the bottom even with the bracket and it is stuck tight. Vice grips will not even make it move. May have been wrong to try and grind the bottom. If that does not work may grind off the top and see if that works.
Old 04-11-2022, 08:02 PM   #6
paul2748
paul2748's Avatar
The TBird vendors have the pin kit. CASCO shows it as part # 76001S. I assume it is the same as a sedan.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-12-2022, 03:14 PM   #7
Hot Rod Reverend
Hot Rod Reverend's Avatar
TeeBird Auto has them like Paul says... at least that is where my replacements came from on my car.
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 04-12-2022, 05:13 PM   #8
56sedandelivery
Got some on order. I ended up grinding off the pin head and it popped right out
Old 04-12-2022, 06:11 PM   #9
KULTULZ
KULTULZ's Avatar
Post Re: 56 Door retainer pin?
Here's the FORD MPC info for the check assembly and pin (76001-S8) -
File Type: jpg DOOR CHECK ARM - (23504) - 1949-59 MPC TXT.jpg (21.9 KB, 23 views)
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
