02-15-2024, 07:43 PM | #1 |
seal
Can anyone shed light on the manufactures name & part number for a rear pinion seal for my 1956 Ford Victoria my rear diff has 322 gear ratio if that means anything?
Thank you for your time. Cheers Oldgas |
02-15-2024, 08:31 PM | #2 | |
Re: seal
The old seal will have an ID NO on it. Take it to a BRNG AND SEAL PARTS JOBBER and they should be able to fix you up. |
02-15-2024, 09:33 PM | #3 |
Re: seal
K’s got it right. But those ford rear ends are not well supported. If you can’t match it locally (wherever you are) try Randy’s Worldwide. Call, it probably won’t be on the web site.
https://www.randysworldwide.com/ring...RoCel8QAvD_BwE |
02-16-2024, 06:41 PM | #4 |
Location: North Warrandyte, Melbourne,Victoria, Australia
Re: seal
National 6371, 410539, 450539,480539,411978N,410467, 450467.
02-18-2024, 09:17 AM | #5 |
Re: seal
Thank you all for sharing your knowlage & direction on obtaining the pinion seal for my 56.
Cheers Oldgas. |
02-18-2024, 10:47 AM | #6 |
Re: seal
02-18-2024, 11:26 AM | #7 | |
Re: seal
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
02-18-2024, 08:15 PM | #8 |
Re: seal
Kultulz,
Are you referring to me as being a " so -called specialty vendor"?......, We've been in business for 54 years...... |
02-18-2024, 08:20 PM | #9 | |
Re: seal
LORD NO! ... I was referring to buying from a trusted parts jobber (which is you) over these online off-shore parts sellers. ... I can get myself into more trouble ...
