Old 05-20-2019, 05:08 PM   #1
gmc4hire
gmc4hire's Avatar
Default rear wheels turn by hand with trans mission in gear
Just rebuilt and installed differential. I noticed I can turn the rear wheels with the transmission in 1st. gear. Is this normal?
gmc4hire is offline   Reply With Quote
Old 05-20-2019, 05:22 PM   #2
dennis lumbert
dennis lumbert's Avatar
Default Re: rear wheels turn by hand with trans mission in gear
If both wheels are off the ground that is normal.If one is on the ground you won’t be able to turn the other one more then a few inches.
dennis lumbert is offline   Reply With Quote
Old 05-20-2019, 05:32 PM   #3
gmc4hire
gmc4hire's Avatar
Red face Re: rear wheels turn by hand with trans mission in gear
Thank you, I have enough gray hair.
Old 05-20-2019, 05:38 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
If you can move both wheels in the same direction there's a problem, if they move in opposite direction it is normal---- that is showing that the differential gears are working
Kurt in NJ is online now   Reply With Quote
