01-31-2018, 09:54 PM | #1 |
Riveting floor pans
I need to rivet the floor pan and other parts together on my 29 CCPU. There are a few places that a 3/16" brazier head 7/16" long rivet may not be quite long enough to get a nice waffle peen. I have 7/16" long steel rivets I plan to use for most places, where they are long enough. I can't find any steel 1/2" rivets, not even at Big Flats Rivet Co. I did buy some 1/2" long aluminum brazier head rivets a while back. Does anyone see any problems with using aluminum rivets on steel metal panel in some places that a 7/16" may not be quite long enough. I have heard about dissimilar metal problems, but I don't know if after painting, an aluminum rivet would pose any problems. Any help responses would be appreciated.
Rusty Nelson |
02-01-2018, 12:23 AM | #2 |
Re: Riveting floor pans
02-01-2018, 09:22 AM | #3 |
I just checked McMaster-Carr via your link and they don't carry brazier head rivets like used on the floorpans and other places on model A's. I have purchased items from them in the past, but not rivets, since they don't have the right kind.
Rusty Nelson |
02-01-2018, 09:28 AM | #4 |
If you are only needing a couple of rivets, why not turn your own on the lathe ?
Will probably take you less time than locating what you are looking for. |
02-01-2018, 10:31 AM | #5 |
eystein,
Unfortunately I don't have a lathe or easy access to one. Rusty Nelson |
02-01-2018, 02:00 PM | #6 |
02-01-2018, 02:19 PM | #7 |
This company should have ANYTHING you need. Their shipping can get a bit pricey if not getting a bunch. To me, brazier head and truss head are virtually the same.
https://www.rivetsonline.com/ |
02-01-2018, 02:23 PM | #8 | |
I used all aluminum rivets to put all new floor pans in my '30 roadster...dozen years ago. No problems yet ...lasts long, works good ! Painted semi-gloss black. Must admit that I am a neophyte and also couldn't get rivets and equipment otherwise. I'm not 'fine point' restorer either ! |
02-01-2018, 02:39 PM | #9 |
I think I will use the aluminum rivets in any places that I need a slightly longer rivet than 7/16" which probably is not that many. Thanks for the responses.
Rusty Nelson |
02-01-2018, 04:22 PM | #10 |
If a person would use a good rivit look alike . The headlight screw rivits work good for me . These screw rivets are for attaching the base plates of the seadlight buckets and they look just like rivets and are stainless steel . they come with lock nuts These screw rivets are on page 85 of Brattons catalog , part number 18280 .You get 12 screw rivits with nuts for $3.95 Most model A vender catalogs have them . I've bought 1/4 galv. carrage bolts by the pound at flee markets . I'm pretty sure some of the name brand bolt and screw companies would have them in different grades of hardness . I like this method of installing floor pans.Nobody is gona be crawling under mine to see the attaching nuts . I usually paint them semigloss or satin black
02-01-2018, 04:59 PM | #11 |
I have a 48 and 49 Piper airplane. The wing ribs are many pieces of formed aluminum assembled with steel rivets. It’s never been a proble. Thousands of them out there with no problems.
