01-24-2018, 01:46 PM | #1 |
Water leak
Hi got another question should water weep out of head when loosening head nut?
01-24-2018, 02:38 PM | #2 |
Re: Water leak
I don't know if it should leak. It is always best to at least drain the coolant to at least below the level of the head before loosening any head nuts . Sometimes you may get by but why run the risk of getting coolant in the oil pan . The model A only has 14 head studs .
01-24-2018, 02:50 PM | #3 |
Re: Water leak
DUH??
Paul in CT |
01-24-2018, 03:07 PM | #4 |
Re: Water leak
Loosening head nuts runs the risk of coolant leaking around the head stud, between the head and block or past the head gasket and into the oil pan . The model A only has 14 head studs , this is a weak point and has less clamping force than any other engine that i'm familiar with .
01-24-2018, 03:08 PM | #5 |
Re: Water leak
Thanks Purdy I Know water jacket is right there just wanted to make sure that it was not a indication of a crack or bad head gasket.Have no water in oil but am having other issues with it.Had this loosen it to put cable clamp back on head.
01-24-2018, 03:19 PM | #6 |
Re: Water leak
01-25-2018, 10:12 AM | #7 |
Re: Water leak
It' best NOT to use a cable clamp!
If a head gasket is TOTALLY LEAKFREE, NEVER loosen a head nut, for ANY REASON!!! Like Purdy said, "There's ONLY 14 headbolts" Bill Practical
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 01-26-2018 at 02:34 PM. |
