03-13-2018, 06:29 PM | #1 |
Crab style Distributor Cap
Will the crab style replace the Y style cap that has the 8 plug wires jammed into the two holes? With out to much modification, 1948 ford with 59 engine,dont know the model of the dist. its stock two bolt. Thanks for any help.
03-13-2018, 06:40 PM | #2 |
Re: Crab style Distributor Cap
Yes,but the distributor has to have two clips to hold it on rather than the bail like your dist. would have.
03-13-2018, 06:48 PM | #3 |
The stock 46 y-style disty has two hold down clips. There was a bail on the helmet version.
[Edit: there is also a bail over the top cap in addition to the clips holding the lower cap]
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it Last edited by FortyNiner; 03-13-2018 at 08:32 PM. |
03-13-2018, 06:57 PM | #4 |
Ok thanks,do you know if the rotor's are the same
03-13-2018, 07:53 PM | #5 |
No, they are different. Most ford suppliers will have both types.
03-13-2018, 08:21 PM | #6 |
Many of the suppliers sell a kit with all parts and pieces required to convert the rabbit ear caps back to a crab cap. You also need to change the rotor.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 03-13-2018 at 08:27 PM. |
03-13-2018, 08:28 PM | #7 |
All I know is that my 46 rabbit ear distributor cap has two hold down clips and a bail over the upper cap.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
03-13-2018, 11:25 PM | #8 |
Yup, you just need the two clips and the rotor that are made for the crab cap to convert the two part dist cap. Check to make sure the crab wires will clear the belt(s).
03-14-2018, 07:27 AM | #9 |
I have a crab type distributor on my French motor.
The clip conversion parts are easily available. I bought a new set of plug wires and spec'd 90 degree terminals coming out of the cap. This keeps the wires out of the way of the pulleys. Mart. |
03-14-2018, 08:06 AM | #10 |
John,
Before you reinstall the distributor on the motor check for rotor internal interference with the cap. The crab cap registers on the outside of the distributor housing and the later type cap registers on the inside of the distributor housing. Charlie ny |
03-14-2018, 09:35 AM | #11 |
Third Generation Ford has the clips you need and they also have the cap and rotor. Great people to deal with , they have a ebay store......
https://www.ebay.com/itm/NEW-1942-46...BXaHwB&vxp=mtr |
03-14-2018, 10:06 AM | #12 | |
03-14-2018, 10:18 AM | #13 |
You are correct. There are two small bail spring clips on the outside of inner cap, and one large bail that goes over top of the outer cap.
03-14-2018, 10:22 AM | #14 |
The rotor is the same as the 49 - 53 rotor.
03-14-2018, 11:39 AM | #15 |
Thanks for all the info. Parts are on order.
Sent from my iPhone using Tapatalk |
03-14-2018, 02:45 PM | #16 |
there is a different set of wire looms used on the crab dist. eng.if you want a neat set up you will need them
