01-12-2018, 07:32 AM | #1 |
Original Ignition Coil
I need to know for a technical presentation, what the secondary high voltage of an original ignition coil is.
Bob Bidonde |
01-12-2018, 10:16 AM | #2 |
Re: Original Ignition Coil
The typical "old" ignition coils put out 5,000 to 6,000 volts, dunno what an original Model A coil puts out.
Maybe someone with an old ignition analyzer scope can supply an actual reading.
01-12-2018, 10:33 AM | #3 |
My original slant pole coil puts out about 12,000 to 15,000 volts.
Check on Vince's website and he might list the specs. I might be able to find them somewhere, but don't hold your breath. |
01-12-2018, 11:35 AM | #4 |
Supposedly the Slant Poles were a little higher voltage around 15,000 volts.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
01-13-2018, 12:04 PM | #5 |
Voltage is dependent on rotor air gap, plug air gap, dwell, compression and fuel mixture. A scope will show you how variable it is. Good for others to know. I suspect Bob that you were looking for maximum value. Think of it as a lazy thing; only climbs as high as it needs, to find ground.
01-14-2018, 08:29 AM | #6 |
Bill W.
01-14-2018, 08:44 AM | #7 |
Wet your finger and put it in the hole, touch ground with your other hand.
If you just say ouch then it is like 5000 volts. If you go ouch then say SOB then your close to 10000 volts. If you say GD, SOB then you are near 15000 volts. If you say MF GD SOB then your around 30000 volts. If your repeat 30000 volts several time then you are around 50,000 volts. At least that is my experience. |
01-14-2018, 09:38 AM | #8 |
Something like this?
01-14-2018, 09:39 AM | #9 |
Thought the old rule of thumb was 1K volts for every 1 thousands of an inch on the gap. If that is close then about 35K volts for a 35 thousands gap. Doubt if it is quite that high, but 30K volts would be close
01-14-2018, 11:30 AM | #10 | |
Thats a good one and I would say you are right on !!! I got shocked once by my 40.000 volt Flame thrower coil . I have been VERY carefull not to let it happen again . All of the vender replacement coils that I have tested with my jump spark coil tester have failed to jump a 10.000 volt gap . I read somewhere that the original slant pole coils put out around 20.000 volts . |
01-14-2018, 11:41 AM | #11 |
I've run the old Mallory Bee Hive coils that have been said to put out 30.000 volts , I could feel a good improvement in performance . The Bee Hive coils are oil filled . By the time that I figured out what I was doing wrong , I had already went through a few of them . Oil filled coils need to be run with the tower pointing upward .
01-16-2018, 01:29 AM | #12 | |
01-16-2018, 03:49 AM | #13 |
I don't know what the originals put out
But a fellow came round to my house last year in a 29 Canadian Tudor that he imported a few years ago . It still had an original Slant Pole Coil on it and it was working fine. Funny thing is he took it off when I told him "that coil is 86 years old"!!!! |
01-16-2018, 10:49 AM | #14 |
01-16-2018, 11:06 AM | #15 | |
