06-09-2023, 10:35 AM | #1 |
brake rods rattle
How do you keep your brake rods from making a rattle at idle? I am considering attaching a spring on each and connecting it to the frame. This should keep tension on each one. Hopefully it will prevent the vibration and keep the noise down.
06-09-2023, 10:41 AM | #2 | |
Re: brake rods rattle
there are anti-rattle springs on the A, at least on mine. Mine were 'a bit weak' and were rattling my little brain out of my head so i got new ones from the know suppliers and since then, that rattle is gone. But, keep in mind, one rattle killed gives birth to two new ones... |
06-09-2023, 01:50 PM | #3 |
06-09-2023, 05:39 PM | #4 |
You need to replace your anti-rattle springs. If done right, you will have no noise.
Enjoy. |
06-10-2023, 05:51 AM | #5 |
wear ear muffs.............
06-10-2023, 05:58 AM | #6 |
I prefer the 28/29 return springs instead of the 30/31 wire style. Mr WHN is spot on in my opinion, rod rattles mean a poorly adjusted brake. |
06-10-2023, 09:05 AM | #7 |
This is my latest practice to quiet rattling brake rods:
Bob Bidonde |
06-10-2023, 09:42 AM | #8 |
:-) zip ties work well too!
06-10-2023, 03:22 PM | #9 |
"Back in the day", special snake-like springs were sold that put downward tension against the brake rods and supposedly reduced rattling noise. They are pictured in Floyd Clymer's "Model A Album" on page 95. I always thought this was a pretty good idea and certainly couldn't hurt anything. I wonder how they were received "back then" and whether it would be worth the effort and cost to reproduce these things, assuming the copyright protection has long since lapsed.
Marshall Last edited by Marshall V. Daut; 06-10-2023 at 03:48 PM. |
06-10-2023, 11:39 PM | #10 |
I have those on my 30 Town Sedan brake rods. I wondered if they were just aftermarket brake rod springs, or what?
Last edited by 1928 Sport Coupe; 06-11-2023 at 12:03 AM. Reason: Missed a photo. |
06-11-2023, 12:43 AM | #11 |
Try this: turn the adjustable clevis off center a bit to add tension to the pin.
06-11-2023, 05:32 AM | #12 | |
If someone has some for sale I would be interested to buy. My contact is bob@hamiltonprecision. |
06-11-2023, 06:45 AM | #13 |
Hi Big Hammer! i tried plastic zip ties, but they eventually wore out.
Bob Bidonde |
06-11-2023, 07:21 AM | #14 |
06-11-2023, 07:39 AM | #15 |
06-11-2023, 07:43 AM | #16 |
The safety factor of ford mechanical brakes.. lose one wheel of brakes you still have three
“All steel from the pedal to the wheel” |
06-11-2023, 09:59 AM | #17 |
WHN:
No I am not driving this car for now. I bought it at an auction this past December, bad choice of time for the seller but good for me. I had to load it up and bring it home in the snow. I have other projects to do but I have been removing parts like the carb, starter, distributor, etc as I can. I take them home to rebuild when I have some spare time. |
06-13-2023, 12:02 PM | #18 |
Here is a later model spring I like, they come with hardware. https://www.snydersantiqueauto.com/p...7613&cat=41655
It's not the destination ,it's the journey . |
06-13-2023, 08:56 PM | #19 |
I saw something like that in a New Zealand magazine a few years ago. They recommended turning and holding the clevis in a twisted position before locking up the lock nut. That put the brake rod in torsion and stopped the rattle.
06-14-2023, 07:31 AM | #20 |
Great idea and simple to do! I expect the small amount of torsion needed on the brake rods wouldn't be an issue? Anti rattle springs could still be in place for the authentic look.
