03-31-2022, 08:10 PM | #1 |
Clutch grabs high
I am getting old and cognition has diminished. My clutch grabs at end of peddle travel , all at once. There is no easing in from a stop. Can I make an adjustment and what would it be?
Thank You |
03-31-2022, 08:14 PM | #2 |
Re: Clutch grabs high
sounds to me someone might NOT have set the pressure plate fingers right.
03-31-2022, 08:16 PM | #3 |
How much free-play is there ?
Probably the easiest thing to try is too increase free-play. |
03-31-2022, 08:45 PM | #4 |
tOUGH TO FIND FREE PLAY AS SPRINGS ARE TIGHT BUT i WOLD GUESS 2-3"
03-31-2022, 11:29 PM | #5 |
Should have about an inch of clutch pedal free play at the top. First, check your clutch arm down on side of transmission case where it is pinned to the clutch shaft, it may be cracked. Snyder's and others sell a replacement arm that should out last the car.
04-01-2022, 07:50 AM | #6 |
If possible, take the car to a mechanic for inspection and repair. A modern clutch and transmission shop should be able to help.
04-01-2022, 09:13 AM | #7 |
i have adjusted the pressure plate fingers while the engine and tranny were still in the car. through the top inspection cover.
i found that this is not an easy job that can not be done accurately. (at least i couldn't) i did however get them close and improved the function of the pressure plate, i looked at it as a bandade until the problem could be dealt with when the engine or the tranny was out of the car.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
04-01-2022, 09:20 AM | #8 |
You have too much free play as others have stated, check for broken worn linkage. Lubricate the TO bearing it has a grease fitting on it, that maybe a cause of the grabbing and stiff Clutch pedal
04-01-2022, 10:11 AM | #9 |
First time I've heard that.
04-01-2022, 12:07 PM | #10 |
I think the pressure plate should come off for the correct and most accurate adjustment. i made this tool for adjusting the finger height. A piece of .125"x1"x7.5" aluminum angle and a small scrap piece of aluminum from when I was test cutting key tags and just glued it on with JB Weld.
Regards Bill |
04-01-2022, 12:25 PM | #11 |
Too much freeplay and the clutch would be grabbing at the bottom,not the top.Sounds like the clutch is either a worn out old one,or the fingers were not adjusted before installing the trans.They SHOULD always be adjusted with a new disc in place.In reality I have not found any problems with one a little worn in.Disc is supposed to be .340 thick,and dead flat.any warpage and all bets are off.
04-01-2022, 12:35 PM | #12 |
The adjustment pin is threaded in as tight as it will go and it is rusted there. I will order a new one and pull up the floor boards and check the pressure plate. The car is drivable as is . Thanks for the info
04-01-2022, 12:36 PM | #13 |
Where are you located?? Might be a club near by that someone could give you some help.
04-02-2022, 04:19 AM | #14 |
Springhill Fl.
04-02-2022, 10:49 AM | #15 |
don't take this the wrong way, but are you adjusting the rod in the correct direction?
i have adjusted the clutch pedal heights many times, and every time i go under the car i have to check that i am adjusting the rod length in the correct direction. i always seams backward to me. just a thought.
04-02-2022, 05:25 PM | #16 |
The adjustment screw is rusted and I will not force. When the new one comes in I will pull boards and cover and do it right
04-02-2022, 05:26 PM | #17 |
Adjustment pin is threaded all the way in and stuck
04-03-2022, 12:25 AM | #18 |
Order the new modern adj rod you can adjust without removing the pin I just put one on my car and was a brease to adj Kevin
04-03-2022, 07:38 AM | #19 |
KW, do you have a picture or part number for the modern rod?
04-03-2022, 08:42 AM | #20 |
