Old 04-11-2018, 07:31 AM   #1
bkensinger
bkensinger's Avatar
Default Start Up and Safety Checklist
My Model A Club is getting ready to start the touring season up north in Wisconsin. Does anyone have a really good safety checklist so we can go over our Model A cars before we tour?
In addition , some of the cars have not had bearings repacked and fluids changed in years due to limited driving. Is there a good rule of thumb on age rather than miles?
Thanks
bkensinger is offline   Reply With Quote
Old 04-11-2018, 07:41 AM   #2
Curtis in MA
Default Re: Start Up and Safety Checklist
http://www.mafca.com/downloads/Safet...0Checklist.pdf
Curtis in MA is offline   Reply With Quote
Old 04-11-2018, 07:55 AM   #3
WHN
It really is not a big process to recommission a Model A.
Change ALL oils, engine, transmission, rear end. Complete lube including u joint, throw out bearing, and steering box. Don’t forget the distributor, points cam, generator, and water pump. Front and rear wheel bearings if over ten years. Check oil in shocks. Check fan belt and hoses. If car has had little use, I would think about flushing radiator.
Important! Get under car and check all the cotter pins. Torque rear axel nuts to 100, don’t forget this one.
Enjoy your summer. Now you have me thinking about uncovering our 29.
WHN is offline   Reply With Quote
Old 04-11-2018, 04:17 PM   #4
30ccpickup
30ccpickup's Avatar
I did this one for fun. If it is missing something let me know.
http://modelabasics.com/Roadside%20T...anicsSheet.htm
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 04-11-2018, 04:41 PM   #5
PeterBo
PeterBo's Avatar
Interesting. I note that the item in your checklist 30ccpickup says to 'Tighten to frame'. My understanding was that the rear muffler support was designed to be oversize to enclose the exhaust pipe and so allow expansion - Not to be tight and lock it to the frame.
PeterBo is offline   Reply With Quote
Old 04-11-2018, 05:01 PM   #6
30ccpickup
30ccpickup's Avatar
I will change it to "tighten clamp at frame" or maybe "check clamp at frame"
Old 04-12-2018, 04:39 AM   #7
pooch
pooch's Avatar
Check the driver for dementia too .
Limited driving and times have changed with texting gap fillers on the road.
pooch is offline   Reply With Quote
