11-26-2014, 01:28 PM | #1 |
Moidel B manifold
Is the Model B exhaust manifold the same as an "A"? Even if not identical can an A exhaust manifold and mufffler be used on a "B"?
11-26-2014, 01:36 PM | #2 | |
Re: Moidel B manifold
No, the outlet on a 1932 Model B manifold is angled towards the rear and will not align with the Model A muffler However, in 1933 Ford returned to the Model A style exhaust manifold and will work on a Model A. Darryl in Fairbanks Last edited by darrylkmc; 11-26-2014 at 01:42 PM. |
11-26-2014, 01:39 PM | #4 |
The B manifold does not drop straight down like the A.It goes back at a downward angle.The A manifold bolts right on to the B block.Hundreds,if not thousands of folks have done it.
11-26-2014, 01:42 PM | #5 |
So does this mean that the B manifold that was angled to the rear was only current pre-1933. Thus any B after 33 will accept the A manifold. Was there any different in the blocks or ports of pre and post '33 models?
11-26-2014, 01:45 PM | #6 |
11-26-2014, 01:49 PM | #7 |
Model B manifold
John,
Visit Vince Falters Ford Garage and look at the Manifold variations. http://www.fordgarage.com/pages/exmancompare.htm Darryl |
11-26-2014, 02:55 PM | #8 | |
Seems that Keith read your question correctly, in that, I believe that you are asking...CAN AN MODEL A MANIFOLD AND MUFFLER BE USED ON A B block . As Keith stated...thousands, including me have done so ! And, NO they , A/B exhaust manifolds are NOT same for reasons stated. |
11-26-2014, 03:16 PM | #9 |
Thanks Guys, your help is much appreciated as always.
11-26-2014, 04:51 PM | #10 |
John, The B manifold is machined out at the Carb. Neck (1.250-1.312). The A manifold is casting finish, 1 3/16. This is not critical but obviously the B manifold will be a little more efficient and give a little more HP than the A.
Terry |
11-26-2014, 05:03 PM | #11 | |
Where this gets confusing is John asked if the Model-A exhaust manifold & muffler could be used on a Model-B, ...which I think many of us understood that to mean the entire vehicle, since he did not specifically state if could it be used on a Model-B engine. |
11-26-2014, 10:23 PM | #12 |
Brent, In rereading it, I believe you are correct! My Mistake, I've got to read more carefully in the future.
Terry |
11-26-2014, 10:41 PM | #13 |
Brent - or anyone - is the inside diameter of a '32 B exhaust manifold larger than the stock Model A ?
And am I reading (and understanding) the post (Dayrrl lin Fairbanks - Post # 2) that indicates that a '33 & '34 four-cylinder exhaust manifold is shaped straight downward, like an A , and WILL WORK on a Model A ? (Whereas the '32 is angled, and will not). This is not what my 1934 4 cyclinder Model C had when installed in the car. Last edited by DougVieyra; 11-26-2014 at 10:48 PM. |
11-26-2014, 11:01 PM | #14 | |
According to Vince Falter the 1933-34 Exhaust Manifold 46-9430 is the same as the 1931 A-9430 Manifold. The 1932 B-9430 is the other animal as Brent described. http://www.fordgarage.com/pages/exmancompare.htm Darryl in Fairbanks |
11-26-2014, 11:50 PM | #15 | |
Since nobody has asked I will, what type of vehicle (stock or modified) are you working with? The answer to that will determine what manifold you need. Charlie Stephens |
11-27-2014, 04:20 AM | #16 |
Sorry for the confusion- It's a 1930 Model A phaeton , with a model B engine. The exhaust manifold needs replacing - it looks like one for an A engine ( outlet points down) , but I thought the B had the outlet angled towards the rear (as per Vince Falters lower photo). It appears the A and B exhaust manifolds are interchangeable so long as one has the correct muffler system. This car thus presumably has an A manifold on the B engine .
11-27-2014, 01:43 PM | #17 |
John Buckley - What you have is what all of us have on our Model A's with B engines. It is what makes sense and works as close to the original Ford design as possible. My only thought is: does the alleged '33-'34 'C' engine exhaust manifold (46-9430) have a wider inside diameter than the Model A exhaust manifold?
11-27-2014, 01:54 PM | #18 | |
Charlie Stephens |
11-27-2014, 04:40 PM | #19 |
Another interesting bit of trivia. The sound we associate with the Model A comes mostly (if not entirely) from the muffler. I had someone pull up in front of my house in what appeared to be a nicely restored Model A. It definitely had the right sound. When he lifted the hood it had a 153 inch Chevy II and a Model A muffler. The '32 sounds more like a modern car. As an aside, the last time I found a correct Model B exhaust system was early 1990's. It was an exact reproduction by Mike McKennett. I haven't seen another one since but if I did I would buy it.
Charlie Stephens |
