Old 05-23-2017, 06:23 AM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Ammeters Model A vs. Model T
Does anyone have good pictures of the front and back of a Model T ammeter?
Since the Model T is negative ground, I assume the ammeter was different than an A, in that the magnet may be flipped so the needle moves the opposite direction.
Anyone know an easy way to spot an A ammeter from a T ammeter? Thanks
Old 05-23-2017, 06:45 AM   #2
Frank Miller
Frank Miller's Avatar
Default Re: Ammeters Model A vs. Model T
The magnet could be flipped or the wires just reversed.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-23-2017, 07:15 AM   #3
2manycars
2manycars's Avatar
The 26-27 ammeter is the same as a model A, except the bezel is flat instead of ribbed. I have some but getting a photo to this computer is a pain. The earlier T ammeters are about twice the size.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 05-23-2017, 07:22 AM   #4
Dollar Bill
Dollar Bill's Avatar
Tom, I found this online - Not sure if it's OEM but does appear to be NOS
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 05-23-2017, 08:27 AM   #5
Brian T
Brian T's Avatar
In addition I believe the model T ammeter had Ford on the face plate,?, where the A did not.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 05-23-2017, 09:13 AM   #6
Bruce Lancaster
...and Ford sold a spacer ring so the late ammeter could be used as the service part for older T's.
Old 05-23-2017, 09:21 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Repros...
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-23-2017, 10:34 AM   #8
Fullraceflathead
Fullraceflathead's Avatar
I thought the Model T one has the FORD Script.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 05-23-2017, 10:55 AM   #9
redmodelt
redmodelt's Avatar
The meter used in the T era did have Ford script on it, maybe the very early A's also (?). The meter does not care if - or + ground as long as the wires are hooked up the correct way for the system.
Old 05-23-2017, 12:56 PM   #10
Tom Wesenberg
Repro, as Brent said. You can even see the brass through the window. Model A's had flat black paint over the brass.
Old 05-23-2017, 01:45 PM   #11
BRENT in 10-uh-C
Tom, you do have my curiosity up when you wrote that comment regarding the magnet and the polarity of the ground. Care to expound on this??
BRENT in 10-uh-C
Old 05-23-2017, 05:09 PM   #12
Tom Wesenberg
This appears to be a nice original ammeter for the Model A, but the owner wanted me to flip the magnet so the yellow battery power wire would connect to the left post, the one closest to the center of the car. This way it would match up with the wiring diagram.
The magnet is very tight to the case, so removing it and installing it takes a lot of care to not damage the needle.
Old 05-23-2017, 07:14 PM   #13
1930 coupe
I have seen original Ford A and T ammeters with the magnets installed both ways. I supposed that they have been worked on many times down through the years and some people just put the magnet back in without checking it. The original wire on a original 28-29 dash lamp is very short and will only fit on the closest ammeter terminal without stretching it very tight. I always turn the magnet so that the terminal closest to the dash lamp is the load side. I find ammeters at swap meets with black bezels and other than the black paint they look like the ones with the chrome bezels inside and outside. The mounting tabs on the original bezels are usually broke or will break when you mount them, so I usually install new reproduction chrome bezels on them.
1930 coupe is offline   Reply With Quote
Old 05-24-2017, 05:47 AM   #14
RonC
RonC's Avatar
The Model T is negative ground versus positive ground for the Model A. An original Model A ammeter installed in a Model T will run backwards. This is same for a Model T ammeter installed in a Model A. The magnet poles are reversed. The bezels on the Model T are flat.
RonC is offline   Reply With Quote
Old 05-24-2017, 06:57 PM   #15
redmodelt
redmodelt's Avatar
All you have to do is swap the wires.
Old 05-24-2017, 08:39 PM   #16
redmodelt
redmodelt's Avatar
Ammeter's Model A, mid 30's V8 and USA made replacement with Ford script, i didn't want to take the cover off to show magnet placement in replacement. Best I can tell is the Model A is original and it reads opposite of the V8. V8 and replacement read the same.
Old 05-24-2017, 08:40 PM   #17
redmodelt
redmodelt's Avatar
and one more of the backs;
Old 05-24-2017, 08:54 PM   #18
Tom Wesenberg
The cheap repro's I've seen didn't have a magnet.
Old 05-24-2017, 08:59 PM   #19
cpf240
cpf240's Avatar
The magnet on the one I got from Bratton's is part of the needle assembly.
cpf240 is offline   Reply With Quote
Old 05-24-2017, 09:07 PM   #20
redmodelt
redmodelt's Avatar
I looked best I could thru the opening, I could not see a magnet around the inside of the case on the replacement.
