Old 04-24-2020, 08:06 AM   #1
fast fredy
Default oil flow
Morning guys , I have a 55 ford 272, have read lots on lack of oil problems to rockers . With engine running how much volume of oil should you see? I see oil coming out the holes in the rocker shafts, but very little coming out the tubes at the end of the shafts.. This my first y block and am more used to a sbc which seems to have a lot more visible flow .. thanks for your thoughts Fred
fast fredy is offline   Reply With Quote
Old 04-24-2020, 01:40 PM   #2
darrell
Default Re: oil flow
very little comes out on most engines your good.
darrell is offline   Reply With Quote
Old 04-24-2020, 04:48 PM   #3
fast fredy
thanks
Old 04-24-2020, 05:39 PM   #4
rotorwrench
rotorwrench's Avatar
If all of them are getting oil there is no problem. The center cam bearing is where it comes from and it has to travel though small passages to get to the rocker shafts. The rockers & shafts have to have clean & clear passages to get it to all the arms. If flow stops for some reason, it should become noticeable pretty quick. Cam bearings can spin in the block if the fit is poor or the rpm is too high and the bearings can wear causing low oil pressure too.
Solid lifter engines run with a bit of lash noise all the time. It's just the way they were made. If one gets too much wear then you will hear it. They all can use a lash check now and then. Use good quality oil and change it per the normal schedule and all should be well & good. Warming the engine all the way up and running it that way for a good bit will usually keep the engine in good shape. Short runs with no warm up can cause a lot of sludge build up.
Old 04-25-2020, 09:24 AM   #5
fast fredy
thanks again
Old 04-25-2020, 03:23 PM   #6
39deluxecp
39deluxecp's Avatar
The pushrods are hollow on a Chevy at supply oil to the rockers. 272 has no oil passage in pushrods.
39deluxecp is offline   Reply With Quote
