01-11-2018, 02:40 PM | #1 |
little help please
I have a 36 2door humpback and am trying to mount an original continental kit on the back, I found an original wide 5 16 in rim but it seems the tire size is important for everything to mesh up, anyone know what tire size was on the originals? also my shell seems to be missing a latch, does anyone have a picture of an original continental package
01-11-2018, 02:55 PM | #2 |
Re: little help please
Seem to recall 6.00-16.
Maybe someone knows for sure.
01-11-2018, 02:58 PM | #3 |
Merc-Ct is correct on the tire size. I will add that the 6.00-16 radials have a slightly larger tire profile and the original spare tire cover will not fit using radials. If you do go with 6.00-16 in a radial just go with 4 and run a good bias ply for a spare so that your spare tire cover will fit.
01-11-2018, 03:00 PM | #4 |
Thanks, anyone know what the latch that holds all the parts together looks like?
01-11-2018, 03:01 PM | #5 |
01-11-2018, 03:03 PM | #6 |
01-11-2018, 03:05 PM | #7 |
I'm talking about the latch that cinches up the outer ring to the face piece, I have the locking hub cap part
01-11-2018, 03:05 PM | #8 |
My '37 used 600-16 and my guess is that the '36 is the same. Check your owner's manual that came with the car. If you don't have one buy one. Reproductions are cheap. It should also be in the restoration guidelines from the Early Ford V8 Club https://www.earlyfordv8.org/Shop.cfm?id=18&pid=2. Again, if you don't have one, get one. These two books are "must haves".
Charlie Stephens |
01-11-2018, 03:12 PM | #9 |
here is what I have, it seems like there is something that should grab the big ring and cinch up but there is nothing there20180112_130338.jpg
20180112_130408.jpg |
01-11-2018, 03:17 PM | #10 |
thanks, just ordered it
01-11-2018, 04:09 PM | #11 |
There is no 'latch' at the bottom of the tire ring. You are missing the round circle on one side that you are suppose to use to pull the ring out, so that you can remove the ring. The ring is held on by it's spring steel shape. Under the cap should be a lock. Other than 3 lug nuts and the lock in the center under the stainless cap, there is no other 'latch'.
01-11-2018, 04:12 PM | #12 | |
01-11-2018, 04:22 PM | #13 | |
The attached photo is of a 1935 but I think it should be the same. |
01-11-2018, 04:25 PM | #14 |
LOL I also have a chrome ring that goes around the center of the tire ring that I cant figure out how it stays in place, I just ordered the manual, hopefully in will have some pics
01-11-2018, 04:28 PM | #15 |
JM35Sedan, Don Rogers, Glenn Sanders or Michael Driskell will be able to shed light on this.
01-11-2018, 04:34 PM | #16 |
There is only one ring on the tread cover, exactly as you have it. The ring helps you to fit the tread cover onto the tire and remove it. You start with the end without the ring. There normally is a rubber gasket on the exterior of the face cover that helps secure the tread cover, but this gets really hard after 80 years. Mostly the tread cover is just held in place by the tire itself.
Here is a picture of a complete spare for a 36 on e-bay now. https://www.ebay.com/itm/1936-Ford-S....c100677.m4598 |
01-11-2018, 04:39 PM | #17 | |
01-11-2018, 05:19 PM | #18 |
01-11-2018, 07:20 PM | #19 |
What you have is correct. The outer ring (Band) has a finger loop on one side only. The 36 does not use the strap around the tire like the 35. There should be multiple slots around the inner cover that are used to attach the chrome strip (unless you have a standard cover which does not have the chrome). If your tire is too narrow, the band will look like yours and cover too much of the inner cover. Tire too wide it wont cover the edge of the inner cover.
Wayne Last edited by wamnram; 03-20-2019 at 07:23 PM. |
