08-26-2019, 05:55 AM | #1 |
engine paint prep
I have Hirsch engine paint for 59L. What prep. is needed other than prep-s0l before painting. Any primer needed ? Thank you Fordbarners.
08-26-2019, 07:13 AM | #2 |
Re: engine paint prep
Usually engine paint on cast iron donīt need a primer.
Aluminum and sheetmetal like the oilpan may benefit from it. Etching the surface with something like metalprep will give you an excellent surface for the paint. |
08-26-2019, 04:07 PM | #3 |
I usually use a rattle can of etch primer as above gives a good grip surface for your engine paint.
Phil NZ |
08-26-2019, 10:33 PM | #4 |
Depends how much time you want to put into it - and what type of paint you have from Hirsch.
I have used Hirsh's paint - it is decent stuff, but the surface prep is everything. I would try to sand/clean it everyplace you can and use an etching primer, then I'd probably shoot epoxy primer over that . . . then the final color. If you want it to look really good . . . then the prep is key . . . if you're using his rattle can stuff, then it doesn't make a huge difference (other than adhesion). I buy his paint in quarts - then do the above to get the block ready . . . then I spray it on. (Just like I'd paint the rest of the car). Good luck! |
08-26-2019, 10:35 PM | #5 |
Here is the engine in my 32 Cab - this is with Hirsch paint (I custom mixed the color):
2015-11-07 18.31.02 copy.jpg IMG_1372 copy.jpg |
08-27-2019, 06:35 AM | #6 |
08-28-2019, 12:52 AM | #7 |
I like that color. Think I will paint my engine red, the car will be black with red wheels so I think a red engine will look good
08-28-2019, 07:04 AM | #8 |
Neat trick. On small spots that you do not want to paint (bolts, etc) wrap them with aluminum foil instead of masking tape. Easier on and easier off. Chap
08-28-2019, 07:56 AM | #9 |
08-28-2019, 09:41 AM | #10 |
Very nice B&S! Like the color.
Glenn |
