11-26-2012, 07:13 PM | #21 |
Re: 1939 Rear Brakes - I'm Going Nutz-O
Reb -
I found that mine had a rust lip built up on the outer edge of the shoe contact area. I Dremeled that down and the drums went on fine.
John Haelig Bridgewater, NJ 1939 Ford Pickup 1963 Lincoln Continental 1939 Buick |
11-26-2012, 09:28 PM | #22 |
Hi, I went through the EXACT same thing you are going through ten months ago. I even did as you have and asked for help on the Ford Barn. It turns out it was the cam adjustment on the rear. A friend of mine came over and did what needed to be done and it worked? I just couldn't do it? Also, heads up, the brakes were tightening up after driving a short distance? That turns out to be the master cylinder needed to be adjusted for the 'free play' on the brake pedal. It wasn't allowing the expanded (heated fluid) to return to the master cyclinder. As a result, the brakes were engaging.........
Thanks again to the good folks at the Ford Barn who let me know what was happening and offered their advise................. You'll get it............ :-) |
11-26-2012, 09:30 PM | #23 |
11-26-2012, 10:22 PM | #24 |
Considering the state of your drums, I would follow Flathead Ted's advice. As he says, he's done a LOT of brake jobs.
11-26-2012, 10:44 PM | #25 |
You should also remember that it is best to use a torque wrench when you tighten up the wheel nuts on a 39 with the wide 5 wheel rims.
The reason for this is the wheel studs are on the outer edge of the drum and not like normal hubs where the studs pull on the axles. If the tension on the wheel nuts is not uniform it can (and will) pull the drum out of round. This can be felt through the brake pedal pulsating like a warped disc does and is particularly noticable on the fronts. |
11-27-2012, 12:10 PM | #26 |
11-27-2012, 01:05 PM | #27 |
Year's ago without much money, I would just get the shoes to fit when assembling and keep adjusting till they wore in . It takes about 1000 miles per adjustment, two adjustment most of the time works fine. Pedel may be a bit soft at first, till the lining wears in. Not rocket science the 39 adjustments are somewhat diffacult to do because the lineings do not float like the later style. I talked to a guy about two years ago that was trying to develop a conversion to get the shoes to float, but have not heard if he was successful. I put a float kit in my 35 (mechanical brakes) and they work great, no need to to convert to hydraulic.
11-27-2012, 05:53 PM | #28 |
I had the same problem. file the slot in the park brake link. it doesnt need much.
That part can actually be what is keeping the drums apart rather than the adjusters, and as long as you can adjust it back out with cable adjustment, you havent upset anything at all, I know its counter intuitive to change that clearance, but it is the answer. trust me. |
11-27-2012, 06:29 PM | #29 |
This problem comes here often with new shoes.
The way it was done without a arching machine. Cammfer the new lining back about 1/2, angle and depth 1/8 on ends. At least near "first rivet". If you bring the shoes out even 3-9 oclock 1/8 less then drum. Most likly they will hit on top thats what the cammmfer is for, do both end. The pistons must be all the way in. The high lining stops the piston from going back in. The angle can be done with file or bench grinder thats what i use. |
11-29-2012, 08:36 AM | #30 |
Thanks, boys. Your generous and helpful advice is appreciated.......
Mike
"There is no 'normal life'; there's just life." - Doc Holliday from the film Tombstone |
11-29-2012, 11:27 AM | #31 |
You could eliminate the problem by using genuine ford lining. already chamfered and the correct thickness. have sold many sets. for 4 linings(2 short and 2 long 32.00 plus postage.
