07-10-2019, 10:48 AM | #21 | |
Re: Odd Failure
I don't even like the new "foolproof" battery chargers - yunno, the one that doesn't work if the leads are inadvertently reversed? I've found that the computer on-board those chargers can be "fooled" as well, and the fooling can result in you buying a NEW battery. Who'd a thunk it - a battery charger that sells batteries? Sort of like don't buy your flashlights from a company that sells batteries? Joe K
Shudda kept the horse. |
07-10-2019, 11:54 AM | #22 |
Re: Odd Failure
Glad you got it running.
I was going to suggest it needed another coin I know it's not a Model A, but it's the closest I could come
07-10-2019, 06:36 PM | #23 |
Re: Odd Failure
Glad you figured it out and thanks for sharing as sooner or later many of us will face the same and gives us pointers on troubleshooting.
07-11-2019, 08:00 AM | #24 | |
Re: Odd Failure-using Smart charger-looks like battery is DEAD.
SMART CHARGERS that have the feature outlined in red above will not start charging if voltage is below 5.5 for 6 volt or 10.5 for 12 volt batteries. To get around this problem charge the battery for a short time with a "dumb charger" to a voltage above the minimum ... then continue with the smart charger. At least that is how the Model 12106 and 12118 Battery Minders work. Last edited by Benson; 07-11-2019 at 09:18 AM. |
07-11-2019, 01:49 PM | #25 | |
Battery tenders/minders are not true chargers and are meant to "maintain" batteries. You get what you pay for, true chargers capable of bringing back batteries that have discharged require a true higher current charger, which cost more. If you delve into the specs of the minders, quite a few of them have a max size battery that is recommended if they are used for charging purposes. Usually the max is a lawn mower battery, motor cycle battery, etc. Car/tractor batteries are more than the max spec. |
