09-29-2016, 02:58 PM | #1 |
Juice brakes
I'm thinking of putting juice breaks on a modified 4 banger RPU. Are their any books or good articles on this conversion? Looking for options on where to mount the master cylinder and pedal. Keeping stock clutch pedal with mitchell synchro trans.
09-29-2016, 03:22 PM | #2 |
Re: Juice brakes
http://www.lainefamily.com/ModelAFil...akeUpgrade.htm
http://www.mtcarproducts.com/MODEL-A-KIT.html (click on each link below...) https://www.clingsaftermarket.com/pr...rakes&subcat=1
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
09-29-2016, 04:01 PM | #3 |
Re: Juice brakes
I like the battery box that is built up to incorporate the master cylinder mount but don't know a supplier at this time. Call around, start with Bert's. Note tat some of the boxes are not strong enough and flex.
Charlie Stephens |
09-29-2016, 06:58 PM | #4 |
Re: Juice brakes
I put juice brakes on my speedster very pleased . I would next time just buy the full kit from MT car products . It's pricey . But in the long run it will save you a lot of time . Plus they where very helpfull .Inmy 30 roadster I have orgianal brakes . Have flathead Teds set up .
09-29-2016, 07:56 PM | #5 | |
Re: Juice brakes
09-29-2016, 07:56 PM | #6 |
Re: Juice brakes
09-29-2016, 07:59 PM | #7 |
Re: Juice brakes
Try an inquiry on the HAMB. Link is on the bottom of the main fordbarn page.
09-29-2016, 08:01 PM | #8 |
Re: Juice brakes
I agree 100%
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
09-29-2016, 08:02 PM | #9 |
Re: Juice brakes
I agree with eagle. Replace the worn parts on the mechanicals for much cheaper and have brakes that stop a stock model a wonderfully
09-29-2016, 08:31 PM | #10 |
Re: Juice brakes
I have both types and see no advantage to the hyds. I actually prefer the Mechanical over the Hydraulics.
Terry |
09-29-2016, 09:24 PM | #11 |
Re: Juice brakes
Obviously, I'm doing something very wrong as the hydraulic brakes on both of my A's neither leak or bind up due to rust. Can somebody help me here?
09-29-2016, 09:40 PM | #12 |
Re: Juice brakes
My brothers Coupe has had hydraulic brakes for 20 years now- no problems. I've had hydraulic brakes on my car for 2 years, no problems. And my car has sat more that it's been driven in the past two years.
Cowtown A's |
09-29-2016, 09:41 PM | #13 |
Re: Juice brakes
09-29-2016, 10:07 PM | #14 | ||
Re: Juice brakes
09-30-2016, 10:57 AM | #15 |
Re: Juice brakes
Go with the hydraulics! There is a reason all cars use them today, they are better and require less maintenance. I've had them on my widebed since 1958. I did have one cylinder rust-up but now run silicone fluid, end of problem! I also have them on my tudor and Vicky. Mostly I made my own mounts, using a 1939 pedal assembly as a base but have used Cling's products which fit very nicely. If you drive your RPU at all, hydraulics are the way to go.
09-30-2016, 11:56 AM | #16 |
Re: Juice brakes
I have seen one well known restorer say that the Mechanicals can be locked up. Now whats a Hydraulic going to do better than that? Locked up with mechanicals or Hydraulics is still locked up. Where do you go from here? Bigger (wider) tires? Bigger drums? I don't know.
Terry |
09-30-2016, 11:57 AM | #17 | |
Re: Juice brakes
09-30-2016, 12:04 PM | #18 | |
Re: Juice brakes
http://www.ebay.com/itm/272385702072
09-30-2016, 02:02 PM | #19 |
Re: Juice brakes
Why do people say "I can lock up all four wheels" locking up wheels and skidding is not in any way stopping. Once again, the best model a brakes are stock ones set up right.
09-30-2016, 02:38 PM | #20 |
Re: Juice brakes
Hahaha, I hear ya! I'm totally doing something wrong.
1931 Model A Victoria 1950 Mercury 8 Member: MAFCA, MARC, Northern Ohio Model A Club www.northernohiomodela.com |
