06-17-2010, 12:14 PM | #1 |
where did the oil go?
got a 36 Ford with a flatheadV8,when cold i have 40-50lbs of oil pressure but as it worms up pressure will drop to 6lbs.Raise rpm will go to 10lbs,go to higher rpm oil pressure drops more.Bearings look good and cant see anything obvious.
06-17-2010, 12:39 PM | #2 | |
Re: where did the oil go?
Gary in MOzarks Last edited by Gary in Mozarks; 06-17-2010 at 05:31 PM. |
06-17-2010, 01:05 PM | #3 |
gary. 3 places to lose oil pressure, one is the oil pump, yes it does have a pressure relief valve, the second are the cam bearings, alot of times these never get replaced on an engine rebuilt in the car, all oil pressure for the engine starts there after the oil pump sends it there, the other places are the main and rod bearings, plasta gage them to see it the clearances are with in specs
06-17-2010, 01:05 PM | #4 |
From the little iv seen
That’s kinda typical oil presser for a older??? Flathead. (seen lower and still run a long time) I think they lose some presser at the cam bearing (most oil go’s there first) Related A friend that builds flathead here locally has addressed this by getting custom cam bearings (one hole) He cuts groves in cam bores (were the bearing sit) to try and direct more of the oil around the cam. Therefore better oil presser at the crank and less spilling from the cam onto the spinning crank. So far this setup has only been used in a couple of race motors. But they did make big HP and set some records in blown street roadster. |
06-17-2010, 01:26 PM | #5 |
I'D put in an m-19 oil pump and 20-50 oil it will live forever. Walt
06-17-2010, 01:44 PM | #6 |
06-17-2010, 02:59 PM | #7 |
one strange thing about ford flathead engines ford never stated oil pressure at idle, all the book says is #35 at 35 mph
06-17-2010, 05:20 PM | #8 |
296, you are a deranged individual! How many of us ol' farts do you want swatting at our monitors to get that bug?! Do you want that on your conscious?! Please take your avatar and my response to the "camaraderie" thread for analysis.
06-17-2010, 06:31 PM | #9 |
I've spraying bug zapper in the back of my monitor..... ain't worked yet...OLD....BILL
06-17-2010, 07:11 PM | #10 |
Love 296 V-8's bug. He's got his figure 8 down pat. Now if 296 V-8 could teach him to do the letter "V" it'd be perfect. Dennis/Arkansas
06-17-2010, 09:31 PM | #11 |
that thing bugs me too
06-18-2010, 11:37 AM | #12 |
hi walt thanks for your reply,im gonna try 20-50 and see how it goes
06-18-2010, 04:28 PM | #13 |
Does anyone know how to get bug spray off of my monitor? LOL
Ross Murphy 1939 Ford Standard Coupe |
06-18-2010, 06:18 PM | #14 |
What walt says.
06-21-2010, 08:17 AM | #15 |
I tried adding a v but any modifications makes him stop moving.
06-21-2010, 09:34 PM | #16 |
Should change to this one?
bet y'all dont swat at her. Last edited by 296 V8; 06-21-2010 at 09:44 PM. |
06-21-2010, 09:42 PM | #17 |
