Old 07-13-2010, 03:35 PM   #1
Steve Rinaldo
Default Spring Liners
On of our region members recently wrote an article about improving Model A ride quality. He suggeted that installing spring liners were a big help. I have some questions about this job:
1. I have a 1930 Tudor what spring is the bestfor the rear and if you have the wrong one can you ad or remove a leaf. If you have to remove one which is best?
2. Which spring liners are best?
3. Can you add the liners with out removing the spring by jus seperating the leaves.
Thanks as always. Steve
Steve Rinaldo is offline   Reply With Quote
Old 07-13-2010, 05:50 PM   #2
Pete
Pete's Avatar
Default Re: Spring Liners
3. Can you add the liners with out removing the spring by just seperating the leaves.
1. Yes., It depends on the ride you want.
2. Best is subjective. I use 1/16 UHMW plastic. It is about 1/3 the price of Teflon and works the same.
3. By dropping the rear end and disassembling the spring all except the
main leaf you can do it.
