Old 01-29-2024, 06:47 PM   #1
ljaynavl
Default Small Bubbles in Transmission Oil
When I removed the shifter tower to inspect the gears, I notices an accumulation of small bubbles in the gear oil (90w). I promptly drained the oil, which was clean looking.
Upon refilling it and leaving it sit a few days, I notice the same gathering of small bubbles.
What would be causing this?
ljaynavl is offline   Reply With Quote
Old 01-29-2024, 09:04 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Small Bubbles in Transmission Oil
is the vent on shift tower plugged small hole facing seat side.
www.whidbeymodelaclub.com
Old 01-29-2024, 09:23 PM   #3
ljaynavl
The whole is open. The bubbling occurred even before setting the tower back in place.
Old 01-29-2024, 09:46 PM   #4
fundytides
fundytides's Avatar
condensation? Is the car in a heated dry garage?
fundytides is offline   Reply With Quote
Old 01-29-2024, 09:50 PM   #5
fundytides
fundytides's Avatar
Sorry, just noticed your location. Heat is probably not needed but very damp conditions or sudden temperature change may cause condensation. Might try a little Seafoam in the oil
Old 01-29-2024, 11:25 PM   #6
ljaynavl
Garage isn’t heated. Chilly winter temps (ok, for the Southern Appalachians). Guess it’s been doing this in the past, though not seen. Perhaps driving simply warms things and get rid of this?
