06-09-2023, 08:51 AM | #1 |
55 steering box
I have about 3 inches play on the steerin wheel of my 55 crown so how much is it safe to adjust the set screw on the steering box without doing harm to the interior of the box..
06-09-2023, 08:58 AM | #2 |
Re: 55 steering box
It's not meant for taking up wear and tear. Only for an adjustment during building.
06-09-2023, 10:15 AM | #3 |
Re: 55 steering box
Put the steering in the straight ahead position. Remove the lock nut and turn the adjusting screw in until it stops, don't force the screw. Then back off just a little so it doesn't touch. Reinstall lock nut. This is all you can do. If you have slack, you have worn pars.
06-09-2023, 11:12 AM | #4 |
Re: 55 steering box
Just to add, I usually disconnect the drag link or center link from the pitman arm so that I can move the steering gears and feel for notches in the movement. If it feels notchy then there are spalled out areas on the worm gear. They ride most of their life in the straight ahead position so that's where a lot of the wear usually is. Once off the straight ahead position, there is more and more play to allow the wheels to steer properly in a turn. This is normal so the only place you can take any slack out is in the straight ahead position.
06-09-2023, 12:09 PM | #5 |
Re: 55 steering box
So a bit leary here...Is the set screw under a cap as i see two heads of bolts or caps and the larger one is the cap over the set screw i presume...When i take that cap off will it turn the set screw or not..Where do i install oil in it and what kind...Thanks in advance...
06-09-2023, 12:55 PM | #6 |
Re: 55 steering box
Often wrong but never in doubt. |
06-09-2023, 05:05 PM | #7 |
Re: 55 steering box
Not very much slack in the straight ahead but more later on in turnso since i can not turn screw i think best to l;eave it alone..Not much sign of lube so going to add some lucas that reminds me of slick 50..Is it possible that the star washer is stuck to the case and the reason i can not turn the screw?
06-09-2023, 05:37 PM | #8 |
Re: 55 steering box
It's been a long time since I adjusted one, but I think the star washer has to come off. Its what keeps the adjustment from changing.
06-09-2023, 06:42 PM | #9 |
Re: 55 steering box
Yes, the star washer has to come off in order to make an adjustment. The washer has a tang that fits in a slot in the screw, then there is a small projection on the steering box that locks the washer in place. Make any adjustments in very small increments to reduce as much slop as possible without causing binding.
06-09-2023, 06:46 PM | #10 | |
Re: 55 steering box
06-09-2023, 07:23 PM | #11 |
Re: 55 steering box
This isn’t a comment on 3” of play. But I believe the 55 and early 56 cars used the 2 sector box, same as the ‘birds. Mid 56 they changed to a 3 sector. Better when new, and less susceptible to wear. That’s probably part of what you feel. You don’t say if you’ve gone thru the rest of the linkage, but it’s all additive. Parts that alone seem “ok” can add up to “not ok” .
06-09-2023, 07:56 PM | #12 |
Re: 55 steering box
Supposedly the Shop Manual has a procedure to adjust for play in the steering box. Trying anything else may bind up the steering , especially in a turn situatin.
