03-01-2023, 07:30 PM | #1 |
Burtz Engine
What is the rated horse-power of a stock built Burtz? What other Chassie modifications should be considered?
Thanks |
03-01-2023, 07:56 PM | #2 |
Re: Burtz Engine
A stock built Burtz engine will give he same power as a stock built original engine. Stock head, cam, carburettor = standard power. No chassis modifications are required because it has exactly the same external dimensions as the original.
The thing about these engines is that they are many times stronger in the bottom end and so, are capable of being "breathed on" to get more than a standard engine would be able to do with any sort of durability and they do it without the vibrations you'd get with an original.
03-01-2023, 08:08 PM | #3 |
Re: Burtz Engine
the bearing area is about equal i figure, building oil pressure takes some power,
The head,cam lifters,valves pistons and all external parts the same exactly the same cam timing I suspect it would be about the same , with the variable of being at minimum clearance versus maximum clearance , balance at optimal numbers or at opposite limits |
03-01-2023, 10:02 PM | #4 |
Re: Burtz Engine
I think there are 2 ways to answer this question. If you build the engine with an original cam and compression ratio you should expect original horsepower. But if it's built with Terry's cam and higher compression head I'd expect an increase in horsepower. Has anyone put one on a dyno with Terry's cam and head then published the figures?
03-02-2023, 01:03 AM | #5 | |
Re: Burtz Engine
The bearing area in an original Model A engine has 3 mains at 1 5/8 inch diameter, and 4 connecting rods at 1 1/2 inch diameter. The new engine has a much stiffer crankshaft with more bearing area because it has 5 main bearings at 2 inch diameter and 4 connecting rods also at 2 inch diameter. |
03-02-2023, 08:03 AM | #6 |
Re: Burtz Engine
The Burtz engine is strong enough to get some modifications, such as a higher compression head and downdraft carburetor(s). The Ford drive train seems to be capable of handling increased horsepower. If you are driving down a level road at 55 mph, you are using the same horsepower regardless of how much the engine is capable of. Point being, under this condition, there will be no difference in the strain on the drive line components.
03-02-2023, 08:17 AM | #7 |
Re: Burtz Engine
50 Horsepower or so.
https://www.fordbarn.com/forum/showthread.php?t=320985 |
03-02-2023, 09:33 AM | #8 |
Re: Burtz Engine
So with a “huge” difference in bearing area and a larger diameter of the journals there would be more friction, and the drag of the oil pump producing 40 lbs pressure compared to 8 lbs pressure (I know the electric drill testing a oil pump output works a lot harder at 40 lbs).
So with everything the same (original stock model A)except for the block,rods,crankshaft would the changes in the intake ports make enough difference to make up for the increased losses due to friction and oil pump load? |
03-02-2023, 10:11 AM | #9 |
Re: Burtz Engine
Yall are really a help -- I thank you.
Now -- I've never driven my '31 PicUp over 45. I get the impression that with the Burtz, I could do more. My 'up-grades': F-1 Ford Steering Box. A 3:54 differential gear. New Radiator. Now would say a speed of 60 be within reason, plz? TKS |
03-02-2023, 12:03 PM | #10 | |
Re: Burtz Engine
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
03-02-2023, 12:08 PM | #11 | |
Re: Burtz Engine
03-02-2023, 12:33 PM | #12 |
Re: Burtz Engine
I had my heavy Fordor up to 73 when I was not paying attention. There was more to go but that was enough for me. Speed was by GPS, not speedometer.
I have the Weber down draft, 5.5 head, Burtz cam, overdrive (3.0 to 1 in overdrive) and that is it. Oh, and I cleaned up the porting a little, just to make the ports smooth, not to enlarge them.
03-02-2023, 03:12 PM | #13 |
Re: Burtz Engine
my coupe that is stock except for a B cam easily goes over 60, was clocked by a state trooper at 62 and that wasn’t flat out— I was asked if it was stock, the troops wanted to see under the hood— grungy original look ,obviously stock, he just shook his head and told me to keep the speed down.
I didn’t tell him it would go almost 70 stock 3:78 rear, have driven it all day at 65 in the past |
03-02-2023, 04:59 PM | #14 | |
Re: Burtz Engine
03-03-2023, 09:56 AM | #15 |
Re: Burtz Engine
I smiled to myself and left him scratching his head.[/QUOTE]
I can't believe you guys drive one this speed. I did hit 45 once and lived to tell about it! Looks like I'll be getting the Burtz, I just got the OK from my Warren. Now at way method might you break in a new engine such as the Burtz? |
03-03-2023, 04:58 PM | #16 |
Re: Burtz Engine
Now at way method might you break in a new engine such as the Burtz?[/QUOTE] Break in is pretty much the same as any other engine. I didn't feel like mine was run in till I had about 1,500 miles on it. As for running at that speed, There are a few things you should do to make your car handle better. No slack in the steering, good shock absorbers and everything good in the suspension including tyres spring to mind. I also believe the soft rear engine mounts cause the car to feel "vague" on the road. I got rid of mine.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 03-04-2023 at 03:46 PM. |
03-04-2023, 02:18 PM | #17 | |
Re: Burtz Engine
I was thinking along that same line,,,, 50 or 55 MPH plus in a Model A Ford??? Are you guys nuts Those skinny little bicycle tires on a 90 year old plus car that the chassis and running gear has been metal stressed who knows how many times? Doors that will pop open if you ram them good and hard with your elbow from the inside? Especially on an open top car?? Speed is meant for Mustangs I'll reserve that need for THAT capacity in one of those, thank you very much |
03-04-2023, 02:51 PM | #18 |
Re: Burtz Engine
A well sorted Model A is capable of 55 to 60 MPH all day. They were advertised to run 55 to 65 MPH even in 1928.
Ad from Literary Digest August 1928 |
03-04-2023, 03:49 PM | #19 |
Re: Burtz Engine
I strongly suspect that those who have given themselves a fright at say, 50 mph are driving cars that need attention. I'd like to see that they have working shockers on them and that the steering etc is good. Mine felt quite stable at 60+mph. A brand new Model A was no doubt just as stable and as has been said, would run at that speed all day.
03-04-2023, 04:29 PM | #20 |
Re: Burtz Engine
If your "A" can't run along safely at 55 MPH, you shouldn't be driving on public roads.
AL in NY |
