Old 12-18-2021, 08:32 PM   #1
Ford coupe
Default 79 granada valve lifters
anyone know where i can purchase a set of 12 oem lifters for a 79 granada with 4.1 engine as the aftermarket ones are to noisy..
Ford coupe is offline   Reply With Quote
Old 12-19-2021, 12:00 AM   #2
darrell
Default Re: 79 granada valve lifters
anyone will have lifters for a 250.they are the same as the fe engines like 390.rockauto and many others.
darrell is offline   Reply With Quote
Old 12-19-2021, 01:13 AM   #3
KULTULZ
KULTULZ's Avatar
Post Re: 79 granada valve lifters
The FORD PN is C8AZ 6500-A.
EvilBay
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 12-19-2021, 12:23 PM   #4
rotorwrench
rotorwrench's Avatar
The Hylift A-2083 should be made in the USA. The Topline Hylift stuff is addvertized to be manufactured here in the US but it's hard to tell if it's true by looking at any given auto part. A person has to check the clearance and make sure it is within the range. If it close to a limit (especially max limit) then a person can change the push rod for a better clearance as long as the push rods aren't too much longer in the next available length.
Old 12-19-2021, 07:52 PM   #5
KULTULZ
KULTULZ's Avatar
No use rotor as he didn't believe this the first go-around -
https://www.fordbarn.com/forum/showthread.php?t=305243
EDIT -
There were three different push-rod lengths released for service/adjust-ability -
1977/ 250CI
STD -9.345" L
.020" U/S
.040" O/S
LIFTER is 1.83" L
