12-16-2022, 08:26 AM | #1 |
Insert leak at water pump
Hello all. I have a question concerning a leak at the water pump insert. I just recently discovered this. Does anyone here have a solution?
12-16-2022, 09:13 AM | #2 |
Re: Insert leak at water pump
A little more information and perhaps a photo would be helpful. Is this a leak proof water pump? Without knowing the details, a rebuild kit may solve the problem.
12-16-2022, 09:17 AM | #3 |
It's not a leakless water pump. I'll take a picture in a bit.
12-16-2022, 11:49 AM | #4 |
Are you referring to the interference between the bushing and the casting?
12-16-2022, 01:14 PM | #5 |
No, I'm talking about the grease insert on the left of the water pump. I can't seem to upload a pic from my pc.
12-16-2022, 02:14 PM | #6 | |
The Model A didn't originally use grease Zerks. Instead on the Model A they're technically known as an "alemite fitting" and relies on your "push" to hold the grease gun sealed against the fitting. IIRC, Alemite is the earlier system used on the Model A. The same producer later adopted the "Zerk" type as production too. This confusing the marketplace as to normal nomenclature. https://en.wikipedia.org/wiki/Grease_fitting#History Quote:
You might try replacing the Zerk with a new Zerk, or maybe retrench and go back to the original cap type Alemite fitting. If this, then you may need two grease guns, or a "conversion" tip which does exist. Imagine having the name "Zerk" as your surname? Joe K
Shudda kept the horse. |
12-16-2022, 05:55 PM | #7 |
If your zerk has the cap then try cutting a small piece of innertube the same diameter of the cap and place it in the cap so when tightened down it presses against the zerk and seals the end of it. You may need two pieces to get it thick enough.
Dave / Lincoln Nebraska |
