12-02-2013, 06:34 PM | #1 |
Block cleaning
Recently there was a thread about block cleaning that referred to something call Never Rust or Ever RUst, or something like that.
I'd like to find that thread if anyone remembers it? Thanks Jim |
12-02-2013, 07:02 PM | #2 |
Re: Block cleaning
"I can't cry as long as I know the Lord has risen " |
12-02-2013, 07:48 PM | #3 |
Re: Block cleaning
Evapo-Rust here: https://www.fordbarn.com/forum/showthread.php?t=123032
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
12-02-2013, 08:11 PM | #4 |
Re: Block cleaning
Tried EVAPORUST, it works but you really need to find somebody who bead blasts the whole bloc. Local guy does it and the results are like a new blck $80
12-03-2013, 09:31 AM | #5 | |
Re: Block cleaning
Then I would take them to the shake and bake as Cpt John says - comes out as clean as a baby's behind .. like new literally! |
12-03-2013, 10:44 AM | #6 |
Re: Block cleaning
12-03-2013, 10:47 AM | #7 |
Re: Block cleaning
Another trick is to get some 1/8" cable, chuck it into a drill, and go down into each water jacket hole from the deck, and also thread it into the water pump holes. Use a slow speed so it doesn't climb back out and slap you in the face.
As to tools, long screwdrivers, welding rod, or anything of the sort that will reach down and scratch well.
I dig coal, which provides motivation for EVs. |
12-03-2013, 12:55 PM | #8 |
Re: Block cleaning
Thanks everyone. Trying to help out a friend
