03-19-2018, 04:28 PM | #1 |
1934 Ford Headlight Stands
Are '34 Ford headlight stands interchangeable from right to left ?
Are the '35-'35 Ford truck headlight stands interchangeable with '34 passenger headlight stands ? Thank you. |
03-19-2018, 04:31 PM | #2 |
Re: 1934 Ford Headlight Stands
They are not interchangable left to right!
03-19-2018, 06:49 PM | #3 |
From my experience the pass car 33-34 headlite stands and mounting bolts are the same as 35-37 truck and pickup parts. The horn mounting brackets however are different between the two..
03-19-2018, 08:07 PM | #4 |
With respect, the head lamp stands for '33-'34 passenger cars are not the same as those for '35-'37 commercial vehicles and trucks. The latter are shorter in height and have different part numbers.
03-19-2018, 09:12 PM | #5 |
That's interesting that and I always like to know new info. I have about 12 pair and they all seem to be the same height and took many from 33-34 Ford cars. No part numbers noted. Laid on a flat surface, they have a max overall height of approx 2 & 1/2 inches. Some even came with 35up pickup horn brackets attached. I think I have seen a few similar brackets at swap meets that are a little taller but were not IDed. Any info appreciated.
03-20-2018, 09:38 AM | #6 | |
The angle of the fender in relation to the headlight bolt is different as is the shape of the fender. |
03-20-2018, 12:54 PM | #7 |
If you put the two next to each other, the difference is plain to see; both in left to right and car to later truck.
