Old 03-05-2020, 12:36 PM   #1
Ken Arms
Ken Arms's Avatar
Default what works?
What should I use to clean Edlebrock heads? I tried some aluminum cleaner and a scrub brush, it helps but does not bring them back to that new look. They are not the polished version but getting very tarnished. I did see someone once that had a spray on rinse off solution that worked effortlessly although I think it was some type of acid that might attack the engine paint or what ever else it contacts. Ken
Ken Arms is offline   Reply With Quote
Old 03-05-2020, 01:28 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: what works?
I used Semi Chrome to polish the primary cover and valve covers on my Harley.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-05-2020, 01:54 PM   #3
rockfla
rockfla's Avatar
Have you tried FLITZ?
Old 03-05-2020, 01:56 PM   #4
mfagan
mfagan's Avatar
Honda has a spray on product to clean aluminum.
Marvin Fagan
214-697-8430
mfagan is offline   Reply With Quote
Old 03-05-2020, 03:16 PM   #5
JSeery
JSeery's Avatar
Just about any type of rubbing on the metal is going to remove the original cast or blasted surface.
Old 03-05-2020, 06:22 PM   #6
37 Cab
37 Cab's Avatar
I have used eagle one mag wheel clearer and have never had a problem with it removing paint. It is an etching cleaner.
https://www.amazon.com/Valvoline-E30...omotive&sr=1-1
Tommy
37 Cab is offline   Reply With Quote
Old 03-05-2020, 09:25 PM   #7
chiefdave
chiefdave's Avatar
For badly tarnished and stained aluminum heads I've found engine paint works best
chiefdave is offline   Reply With Quote
Old 03-05-2020, 09:38 PM   #8
Zax40
Zax40's Avatar
I bought a set of these fine wire brush tips for my Dremel tool and went to work. It worked great. Use the cup and pen shape for between the fins and around the head bolts and the wheel shaped ones for the big flat areas. Use medium speed on the Dremel tool, take your time, and expect to go through several tips. Make sure to wear glasses you don't want one of those fine steel bristles in your eye.
https://www.amazon.com/Drill-Warehou...GYAWF638FX7B4X
Zax40 is offline   Reply With Quote
Old 03-05-2020, 09:45 PM   #9
tubman
tubman's Avatar
"Zax40" - Do you use the brushes dry or with some compound or polish? If so, would you mind sharing?
Old 03-05-2020, 09:59 PM   #10
Zax40
Zax40's Avatar
Just used them dry, I was impressed by how well they worked.
