02-10-2014, 05:03 AM | #21 |
Re: How have you kept your engine warm at night outside?
Hi Old Henry.
Cant imagine other solutions than the ones already pointed, but, risking going offtopic, I want to ask if you keep you car outside and what weather protection do you give Old Henry. Thanks |
02-10-2014, 07:36 AM | #22 |
Old Henry, with the temp this year being in the negative range equipment we receive has a battery wrap/pad that plugs in to 110 Volt. This works wonders on the man lifts. With the motels you have to stay at the high wattage heaters would be hard make work, finding a receptacle that would handle the load. This one is just 60 watts. I am sure there are others.
. KAT'S Heaters/120 Volt 60 Watts 5 1/2 x 8 1/2 in. battery pad heater Part Number: 22400 Alternate Part Number: BH4 . Also, if you can use a momentary push button that by-passes the ignition resistor when starting. This will give the coil additional voltage (hotter spark) |
02-10-2014, 07:50 AM | #23 |
Old Henry:
The Mag oil pan heater & dip stick heater are really only Maintainers that help Martainn the all ready warm engine / That is why such low wattage. The best type is the water circulating ones but you all ready talked about the install headache. Henry may not like it but when at home leave him out side on a cold night have the engine up to operating temp. install the pan heater and see what that gets you. When you used the starting fluid did you remove the air filter or did you spray under the filter trying to get it through the oil bath? ( as mentioned before the oil in the oil bath filter may be to heavy) try starting with cover off the filter. The last thought I have is you have had your share of electrical problems this past year, I know you don't want to hear it but it may be time for a complete wiring up grade. Before Henry Makes a Ash of him self.~ just a thought~ |
02-10-2014, 08:14 AM | #24 |
Professor,
I would try installing a jumper with a toggle switch to bypass the resistor when starting. This will give 6 volts to the coil instead of 4 thru the resistor and make for a hotter spark. Easy to do and helps in all starts hot and cold. John |
02-10-2014, 08:48 AM | #25 | |
I dig coal, which provides motivation for EVs. |
02-10-2014, 09:15 AM | #26 |
02-10-2014, 09:48 AM | #27 | |
Later Fords certainly do. |
02-10-2014, 09:50 AM | #28 |
I leave it my 80 degree garage. When I want to warm it up, I leave it outside during the day and it heats up to 86 degrees. Not to worry north people, spring is just around the corner. :-)
02-10-2014, 10:02 AM | #29 | |
6 volt 4 term ford tractor solenoid. http://www.tractorpartsinc.com/ford_..._2676_prd1.htm Last edited by Tinker; 02-10-2014 at 10:30 AM. |
02-10-2014, 10:06 AM | #30 |
I remember back in the good ol' days when the Fords were considered the best to start in cold weather. The reason given: The starter turned the engine faster than other makes.
True story. When I was first married I bought a 1954 Pontiac from my brother-in-law as a second car for $75. Later traded it for a 1963 Corvair and gave big bucks difference. One cold morning the Corvair refused to start and I walked to work. Just as I arrived at work my old Pontiac flew by with it's new happy owner!
Son, you will never blow an engine up in high gear. |
02-10-2014, 10:06 AM | #31 | |
Richard
twodeuces |
02-10-2014, 10:28 AM | #32 | |
Thanks for asking.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
02-10-2014, 10:54 AM | #33 |
Looks like a lot of good ideas. The challenge will be to find a motel with an outside plug. But, I used to do it back when the engine still had the head bolt heaters in it so probably can again. One more reason to stick with the little old dive motels where I can park right at the door. The real old ones have enough gap around the door to run the wire from my room if necessary.
Thanks for the help.
02-10-2014, 11:02 AM | #34 | |
02-10-2014, 11:33 AM | #35 |
Professor, With an ignition system that dirty, plug wires and plugs dirty and if you have a radio, probably carbon center wires that are broken down, it is no wonder you would have starting trouble. Even dirty spark plug porcaline will rob power. Back in the 40s the only cars on my dads used car lot you could depend on to start on 0 degree days was the flathead fords. Clean all the wireing, Have the coil checked (Skips in Fl.) change the spark plug wires and I will bet it will start on the coldest days. My old 35 does even with medeoaker compression. "Have a nice day" Keith oh
02-10-2014, 11:39 AM | #36 | ||
Haven't checked compressions since engine was rebuilt in June.
02-10-2014, 11:40 AM | #37 |
I'm not sure where you could find head bolt block heaters.
It was a delicate operation to get them out without damaging them. Mine were located more central on the head, pretty much right under where your oil filter is. I cleaned them up and bench tested them, they got real hot real fast. I'll be reinstalling them for the novelty if nothing else. |
02-10-2014, 11:44 AM | #38 |
Mike, what John is talking about will work excellent. It's just a couple wires and a toggle switch that loops around the resistor (the original resistor is under the dash, also best to use a toggle that you have to hold in the on position, when you take your hand off it automatically goes to the off position). I guess you could start from the ignition switch too.
The solenoid version will only be on when the starter button is pushed. It is automatic on/off. ***If this is what you are asking: best to my knowledge there was never a factory bypass. This was a modification that was done by the owner. Best to my knowledge anyway, which is just that :]' . Last edited by Tinker; 02-10-2014 at 01:41 PM. Reason: add stuff |
02-10-2014, 11:51 AM | #39 | |
Everything is pretty new and clean - plugs, wires, distributor, coil rebuilt by Skip Haney. Runs great at all temperatures but doesn't start below 20°.
02-10-2014, 12:20 PM | #40 |
I've read all of these, and I haven't seen any mention of a frozen gas line. This used to be quite common up here in Minnesota, and we would throw in a can of "Heet" every fill up or two. This was especially a problem on cars that were usually kept in heated garages and left to stand outside occasionally (condensation in the tank). With the stock fuel system on a flathead, any bit of restriction on the flow is going to cause problems.
Also, when I was in college, I had a '52 as a daily driver with a "weak" engine. I had a 1200 watt tank heater on it and never had a problem starting it. Believe me, keeping one bank of a flathead at 120 degrees on a sub-zero day is really all you need to do. |
