11-03-2014, 08:52 AM | #1 |
Model A V.I.N.
I have a question:
I know the engine number is used as the car number on Titles. Here is the concern. 1. The number was also stamped on the frame however the body covers this number and often the frame is corroded so you could not read it even if you could see it. In Kentucky: The Sheriff is required to inspect all cars coming into the state and obtaining Kentucky vehicle titles. So.... If your title has the engine number on your out of state title and you have changed the engine the number on engine will not match the number on the title. Mine is fine with an out of state title where the number matches however; I would like too put this original engine number on the firewall so if the block is changed in the future the number is still on the car which matches the title. Does anyone make a tag I can stamp the number on and attaché to firewall? I see where you can purchase a body tag for a Briggs body. Is the 29 closed cab a Briggs? Thanks Barkleydave |
11-03-2014, 09:13 AM | #2 |
Re: Model A V.I.N.
I would ask your DMV about that so as to have problems in future.
11-03-2014, 09:36 AM | #3 |
Re: Model A V.I.N.
I believe some states issue a state ID tag.
Gene USN |
11-03-2014, 09:51 AM | #4 |
Re: Model A V.I.N.
I asked that question to the VA DMV. I got back a very long email that essentially states an engine replacement makes the vehicle a "reconstructed" vehicle requiring a new inspection and the state assigning a VIN. When I went through this process years ago for a kit car, it was the same process with the state inspector riveting a metal VIN plate into the passenger door sill. The VA DMV email is too long to repeat here but for anyone interested, PM me and I will forward it to you. If I were to enter this process again for a Model A, I would first go to my local AAA office and ask for advice. There are also some other approaches to this unnecessary (in my opinion) problem.
11-03-2014, 10:20 AM | #5 |
Re: Model A V.I.N.
11-03-2014, 10:44 AM | #6 |
Re: Model A V.I.N.
you stamp........... |
11-03-2014, 10:46 AM | #7 |
Re: Model A V.I.N.
Ask your local DMV!!! Aside from the problems you would have with them if I was buying a car with a home made VIN plate I would be very suspicious. If I was a peace officer that stopped you I would be very suspicious. In both cases I would dig further. The body tags are just that, a tag to identify the body and not intended to be used as a VIN. They were only installed on bodies not made by at the Ford plant. In California, at least it used to be, if you brought in a vehicle to register with paperwork matching the engine they would install a plate on thee door with their own assigned number. In case you missed it earlier, call your local DMV!!!
Charlie Stephens |
11-03-2014, 12:15 PM | #8 |
Re: Model A V.I.N.
Look up on the MAFCA and MARC national Model A sites for clubs in Kentucky and get the information you need right from those in your state. We have idea's on how it can be done and even how we did it in our state but the best way is to speak with a Model A owner in your state in my opinion.
11-03-2014, 07:19 PM | #9 | |
Re: Model A V.I.N.
If you use this option, I would do your own stamping or have someone with number stamp do it so you can get it to look the way you want it to look. Been there and done that and found my advise would be the best.
11-03-2014, 07:28 PM | #10 |
Re: Model A V.I.N.
Agree 100%
11-03-2014, 08:29 PM | #11 |
Re: Model A V.I.N.
Interesting question, my Model A does not have the original engine but the S/N matches my title. Now if I replace my engine some day, I'd likely have to hang on to the block that matches the titles... The final solution is true VIN-less cars like all Model A are to get state issued VIN as discribed above.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
11-03-2014, 09:28 PM | #12 |
Re: Model A V.I.N.
A lot of times when the engine is rebuilt or changed the number pad is machined and
the original frame number stamped back on the motor. Also when I restored my car I took pictures of the frame number and a tracing or rubbing of the number then used a 48-53 ford truck patent plate that has a space for the i.d. number and stamped it there also. It fits right where the Model A patent plate goes you just have to punch the holes where the Model A holes are or add two more holes in the fire wall for the lower holes. |
11-04-2014, 11:33 PM | #13 |
Re: Model A V.I.N.
When I restored my Tudor, I stamped the original VIN on the top flange of the frame next to the battery. On most Ford bodied cars with all steel sub rails, there is an area of the top flange of the frame next to the battery that that is visible when you remove the floor board. I used original style stamps and used a star stamp at the beginning and end, just like the original ford stamping.
This way, if DMV wants to see the frame number, I can remove the floor board and show it to them. Most of the time, they do not know on a Model A, the original stamping is covered by the body. I also have a B Engine in the car and it seems to also have the original VIN stamped on it Before I installed the body, I also took pictures of the original stampings and even had a friend who does DMV verification and title work verify the original frame numbers. I feel for the guy who buys a car out of state and has to lift the body to have the numbers verified. Chris |
11-04-2014, 11:53 PM | #14 | |
Re: Model A V.I.N.
Darryl in Fairbanks |
11-05-2014, 12:05 AM | #15 | |
Re: Model A V.I.N.
My B block did not have numbers on it when I started with the rebuild BUT for some reason when I was ready to install it in the chassis, it had the same VIN as the original VIN of my Model A. I did this because if I was ever stopped and the officer questioned the registration as not belonging to this car, I can just raise the hood and show him the numbers on the engine match the registration. Also, with the hood up on the drivers side, most Model A people do not catch on that it is a "B" engine. Just having a little fun. Chris |
11-05-2014, 12:09 AM | #16 |
Re: Model A V.I.N.
Chris,
I understand, for some reason I have a Pick-Up with a B engine that also has a matching number on it. Darryl |
