Old 04-15-2011, 03:47 AM   #1
flatheadfan
flatheadfan's Avatar
Default '51 Ford Tool needed
To remove dash bezels on a '51 requires a small round tool that has four spokes on it. I tried using a blade screw driver but it makes a mess of the bezel and can't get things tight. Does anyone know of a source or substitute for this tool?
Thanks
Tom
flatheadfan is offline   Reply With Quote
Old 04-15-2011, 05:56 AM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: '51 Ford Tool needed
I took a piece of steel gas line and filed it off leaving 2 prongs and used a pair of pliers and turned it right off.
Cecil/WV is offline   Reply With Quote
Old 04-15-2011, 06:03 PM   #3
flatheadfan
Thanks Cecil for the tip!
Tom
Old 04-15-2011, 07:18 PM   #4
kraken
kraken's Avatar
I bought one at Mac's in Lockport 2 years ago. It cost about $8.00. It was not listed in their cataloge, but at the time I called them, they had them in stock.
kraken is offline   Reply With Quote
Old 04-15-2011, 08:26 PM   #5
paul2748
paul2748's Avatar
These are readily available through the old car parts houses. They have two prongs. The TBird parts houses also sell them. I think they are called Bezel Nut Tools.
Old 04-15-2011, 08:56 PM   #6
sp1ke
sp1ke's Avatar
you can also use a bladed screw driver
SW-FLORIDA
sp1ke is offline   Reply With Quote
Old 04-17-2011, 07:43 AM   #7
butchbov
butchbov's Avatar
I use one of my wife's pickle forks. Cut the center tine out, cut the tips off the other two & bent them over 90%. Works great on bezels, but not so good on pickles
Butch
In a world filled with stress it is better to give than to receive.
butchbov is offline   Reply With Quote
Old 04-17-2011, 08:28 PM   #8
V12Bill
V12Bill's Avatar
I have used two small screwdrivers and levered them behind the shaft (choke rod, throtle rod, light switch rod, etc) that comes out of the bezel.
V12Bill is offline   Reply With Quote
