01-25-2016, 09:21 PM | #1 |
Today's triva question.
What is it?
01-25-2016, 10:00 PM | #2 |
Re: Today's triva question.
I dunno but there are too many twists per inch in the safety wire making it brittle and the grade 8 bolt is probably overkill.
Lonnie |
01-25-2016, 10:06 PM | #3 |
Distributor block off? Or some type of freeze plug.
01-25-2016, 10:23 PM | #4 |
Does look like a freeze plug????
01-25-2016, 10:26 PM | #5 |
A device to prevent loss of your favorite allen and hex bolt
01-25-2016, 10:33 PM | #6 |
01-25-2016, 10:35 PM | #7 |
01-25-2016, 10:43 PM | #8 |
A thingamajig or do hicky one. Hard to tell.
01-25-2016, 11:00 PM | #9 |
A flywheel/damper for a toilet paper dispenser.
01-25-2016, 11:15 PM | #10 |
MEMBER EMERITUS
An Australian heavy duty contraceptive device.
01-25-2016, 11:55 PM | #11 |
Looks like a special aluminum or steel plug made to seal off the fuel pump push rod area in a Flathead engine, by using the tension of valve guide retainer/crows foot, held in place by a hex head machine screw, and a hex head bolt through plug, and threaded into plug to block off hole for mechanical fuel pump push rod. The saftey wire feature is to help keep hex head bolt from backing out
01-26-2016, 12:41 AM | #12 |
The photograph is of a clever device created for the sole purpose of quietly entertaining the old man where confined by Mama to the computer room. Mama's peace of mind thus preserved for an indefinite period, she is enabled to proceed with her daily toils cleaning up after the old man.
Alan |
01-26-2016, 06:20 AM | #13 |
A nose piercing lug for an eighteen year old girl with tatts on both legs.
01-26-2016, 08:37 AM | #14 |
safety wire practice device.
01-26-2016, 10:17 AM | #15 |
Block off for oil pump hole for an external dry sump setup.
01-26-2016, 12:15 PM | #16 |
I vote for thingamajig.
Rowen
Alive n kickin n mostly kickin! |
01-26-2016, 12:28 PM | #17 |
It's a redneck CD player (needs work).
01-26-2016, 01:55 PM | #18 |
01-26-2016, 02:17 PM | #19 |
With Pete, the raciest answer is always the correct one!!
01-26-2016, 06:24 PM | #20 |
