Old 01-29-2019, 11:27 AM   #1
Ken Arms
Ken Arms's Avatar
Default 34 tudor window fuzzies
Help! Enclosed are pics of what I have from vintiques to replace the fuzzies at the top of rear windows on my tudor. They are in no way like original and I am hoping someone may have a good solution as to how to install. The kit came with no directions. There is a bag of very small counter sunk screws with kit. is there a better source than vintiques for this? Ken
Ken Arms is offline   Reply With Quote
Old 01-29-2019, 08:06 PM   #2
TJ
TJ's Avatar
Default Re: 34 tudor window fuzzies
I could be wrong, but I think that Vintique is the only game in town. Most of the vendors including Drake sell the Vintique window stuff.
Old 01-29-2019, 10:33 PM   #3
FortyNiner
FortyNiner's Avatar
Steele Rubber is your new best friend: https://www.steelerubber.com
Old 01-30-2019, 10:21 AM   #4
TJ
TJ's Avatar
Thanks for the link. Steele used to be GM oriented, but it looks like they have a lot of Ford stuff.
Old 01-30-2019, 12:23 PM   #5
Ken Arms
Ken Arms's Avatar
forty-niner, Thankyou for your response, I went to web site and the kit they sell is what I have from vintique . I think TJ may be correct. I wish they would include some type of install directions. Must be some 33/34 barners out there that did this. The big issue is the rear windows and the large curved metal piece that fits in the top rear of the glass inside the opening. Its a two piece channel spot welded together with u shaped fuzzie clipped in place down the edge originally.You can see it in pic #1
Old 01-30-2019, 04:32 PM   #6
JSeery
JSeery's Avatar
Might try posting on the HAMB as well. Several guys over there that rebuild bodies.
Old 01-30-2019, 07:11 PM   #7
rich b
rich b's Avatar
As an alternative; couldn't you remove the existing material from the tin pieces, rivet in a section of straight track in the top as it appears it was originally done in your picture, then glue replacement fuzzy liner into the curved section folded over the outside and trimmed for a neat appearance.
I bought a roll of 2" wide fuzzy liner and used it for a similar project. The material comes in various widths and sizes, just search window channel liner on ebay.
rich b is online now   Reply With Quote
