06-01-2015, 09:15 PM | #1 |
Houdille Shock Help?... DIY
I wanted to remove my front shocks and send them out to be rebuilt. I removed the driver side shock first from the frame, but that is where I am.
It seems I can't get the shock lever to release from the other parts of the arm that controls the lever on the shock. Is there a special trick to removing these parts? Are they press fitted? Do you need a wheel puller? I have used liquid wrench and bolt blaster but nothing seems to make these parts separate. I'm afraid to bang on the bolts with a hammer in fear of damaging the threads. So for now the shock is just hanging there until I figure out what needs to be done. Thanks for any help will be appreciated.
"DON'T CRUSH IT....RESTORE IT" |
06-01-2015, 09:32 PM | #2 |
Re: Houdille Shock Help?... DIY
You will have to include the year and type of link ---some were rivited together, some had bolt on arms --some the links have a taper like a tie rod end
06-01-2015, 11:37 PM | #3 |
These are on a 1938 Coupe and this looks like a taper like tie rod type. They look like they are the original shocks and have never been replaced. The metal flashing that covers the bolts holding the shocks onto the frame are still riveted in from the factory.
06-02-2015, 01:03 AM | #4 |
U-joint puller for a truck fits over the end of the arm.
06-02-2015, 04:38 AM | #5 |
Some previous posts on same subject. Search function here can be your friend
https://www.fordbarn.com/forum/showth...ove+shock+link https://www.fordbarn.com/forum/showth...ove+shock+link https://www.fordbarn.com/forum/showth...ove+shock+link https://www.fordbarn.com/forum/showth...ove+shock+link
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 06-02-2015 at 04:44 AM. |
06-02-2015, 04:40 AM | #6 |
Dwayne |
06-02-2015, 05:22 AM | #7 |
As said above but leave shock bolted to frame or it will all be swinging in the breeze.
06-02-2015, 06:36 AM | #8 |
Put a hammer under the ring on the arm and hit the top of the ring with another hammer. After a few whacks the tapered link fastner will pop out.
06-02-2015, 08:49 AM | #9 | |
Of course a "pickle fork" tool is the right way to remove a tie rod end, however, I know several front end repairman that just smack them with a hammer, that is backed up on the other side with a hammer..
Bill.... 36 5 win cpe |
06-03-2015, 03:21 PM | #10 |
Thanks for all the great advice.....Bought a pickle fork at good old Harbor Freight for $9 and after a few hard smacks...wah laaaaaa!
06-03-2015, 04:25 PM | #11 |
A pickle fork will do the job, but after destroying some good reusable links and steering rod ends, I stopped using those. I use the two piece, riveted together dog bone shock links on my '35's and rebuild those with new rubber balls. I even messed up a couple of those once with a pickle fork, but not any more.
06-04-2015, 12:09 AM | #12 | |
