03-13-2024, 02:38 PM | #1 |
Cleaning out my cams
Going threw my old cams looking for the 300 jr I had in the stockcar I ran across a weber caO4oX with .402 lift. Don't my setup together to check duration and was wondering if Pete might have a list of weber cams better than the old advertizing one I have.
Thanks Granps |
03-13-2024, 02:46 PM | #2 | |
Re: Cleaning out my cams
03-13-2024, 03:22 PM | #3 |
Ron,
Can you double check that number? I think any Weber with an X at the end indicates it is a radius lifter cam. |
03-13-2024, 07:04 PM | #4 |
Weber F4 is 282 duration and 340 lift.
03-13-2024, 08:19 PM | #5 |
Yes, the lift is what threw me off, that's alote of lift for an old cam. I'll clean it up and have my daughter read the numbery, much newer eyes.
Gramps |
03-13-2024, 09:21 PM | #6 |
Then I went to a cam that Tom Hutchinson called the "awful awful" (don't know the actual grind numbers/letters) - an Erson grind with .450 lift and a ton of duration - and added a blower. Now that was the cat's ass. LOL Didn't really want to idle below about 1200 . . . but it was fun! LOL Last edited by Bored&Stroked; 03-13-2024 at 09:28 PM. |
03-14-2024, 04:12 AM | #7 | |
03-14-2024, 01:58 PM | #8 |
We all have had a degree of learning by way of cams over the years. My little 258 blower combination on the street ran strong with a Potvin 3/8 super we figured it was making a good 300 HP. Same engine testing in my 3000 pound race car at the 1.5 mile speed trap ran 171MPH at the timers. Another great cam I ran and still have is the Crane R-450 anything over 450 lift would be to big to fit threw the flathead cam bearings so that was the limit from what I know.
Another good choice I used many times was the old reliable L-100 ground using the original Laterio cam grinder and master. And lastly from the good old days I ran the Potvin 425 ground on the 32 steel cam. Don't know where that one ended up can't find it in my stash of stuff! Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-14-2024, 02:31 PM | #9 |
03-14-2024, 06:27 PM | #10 |
No, this iz just one of the cams I had in the junk pile. The Sig Erson D410 replaced the 400jr. Went Threw a few more today, but didn't find anything worth talking about. Too cold to stay too long in the shop, so i skipped out I was thinking of setting up sablock to check duration as well but haven't found any interesting cams yet!!
Gramps |
03-14-2024, 06:30 PM | #11 |
Speaking of old cams, curious if anyone has ever used a grind from Racer Brown?
03-14-2024, 06:51 PM | #12 |
03-15-2024, 11:01 AM | #13 |
RR I used an L-94? In an engine when I had a few and wish I had it back. Much better street cam. Same sound but more low end torque. You probably have the specs there someplace. I misplaced mine along time ago/
Gramps |
03-15-2024, 01:16 PM | #14 |
Taking inventory of my cams, I ran across a NOS Wolverine #933. Seems like a pretty useless grind with 280/268 duration and 52 degrees overlap with only a .320 inch lift.
Those who do not move do not die, but are they not already dead? Last edited by John R; 03-15-2024 at 02:48 PM. Reason: Correction |
03-16-2024, 10:43 AM | #15 |
John R, Sounds like a good street cam. Good low end torque and fuel mileage. Think Application With the cost of changing the cam. aesthetics are too expensive.
Gramps |
