Old 08-12-2023, 04:53 PM   #1
ndnchf
ndnchf's Avatar
Default Added LED lights to my '35 Fordor - wow!
I installed LED head light and tail light bulbs in my 6v positive ground, generator equipped car. I'm very pleased with the result, much better rear visibility and I can see in front of me much better. They came from LEDlight.com.
My generator's 3rd brush is set for very low output. The LEDs draw so little current, I still show a slight + charge on the ammeter with the lights on.
I also have a wireless, motion sensing, magnetic mount third tail/brake light for added visibility. I feel a lot safer being out after dark now.
ndnchf is offline   Reply With Quote
Old 08-12-2023, 05:51 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Added LED lights to my '35 Fordor - wow!
Originally Posted by ndnchf View Post
I installed LED head light and tail light bulbs in my 6v positive ground, generator equipped car. I'm very pleased with the result, much better rear visibility and I can see in front of me much better. They came from LEDlights.com.
Old 08-12-2023, 07:26 PM   #3
Merc Cruzer
Merc Cruzer's Avatar
Couldn't agree more, if you re staying with the original generator and 6 volt pos ground system, you will love them. Now replace you dash and interior lights with LED's. I replaced my fog lights with LED's too, all from LEDlights in Phoenix. Go with LED stop and turn signals and then switch out the flasher unit for a LED compatible unit.
Love your car.
https://www.fordbarn.com/forum/showt...22#post1796222
https://www.fordbarn.com/forum/showt...56#post1798056
https://www.fordbarn.com/forum/showt...33#post1785333
Merc Cruzer is offline   Reply With Quote
Old 08-12-2023, 09:37 PM   #4
John R
How sensitive is the "motion sensing" of that third brake light? Does it come on if you just take you foot off the gas or only when braking? Did you get it from LEDlights.com?
John
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 08-13-2023, 04:11 AM   #5
ndnchf
ndnchf's Avatar
I forgot to mention that I have turn signals (signalstat). I bought the recommded electronic LED compatible flasher. It works great.
The 3rd brake is called Bike Spark. Its made for bicycles, but I adapted it to the car using magnets. Google it for more info. It will come on sometimes just by letting off the gas. I like that it does that. It also has a tail light mode that is on when in motion. A very nice safety upgrade that is easily removed for shows.
Old 08-13-2023, 05:15 AM   #6
aussie merc
aussie merc's Avatar
nothing wrong with that so much better 6 volts no longer a problem as most modern automotive LEDs are rated 6/36 V
aussie merc is offline   Reply With Quote
