06-14-2020, 02:28 PM | #21 |
Re: Can this be saved?
Your assumption is correct comrade,the peoples republic of commiefornia..I live in the Central Valley with the rest of the slaves.
06-21-2020, 09:19 AM | #22 |
Went back to the well,the water is dirt cheap . 2 8BA builders,truck bellhousing.Got a degree in banger engines,now I'm going to V8 school. |
06-21-2020, 10:43 AM | #23 |
Chuck those engines into a tank of water and leave them to soak for a month, then try a big block of wood and tap the pistons. If they still wont budge, then put it back into the water another month and try again. Motors with severe rust may take up to 3 months to come loose.
Water caused the rust and will also disolve it, works better than penetrating oil or acetone. I recently did a Model A motor that was rusted solid, after a month, I got all the pistons and valves out, plus got the rings and gudgeon pins out, no problem. Got this info out of a Aussie hot rod mag and believe me it works, you will be amazed |
06-21-2020, 10:53 AM | #24 | |
I do believe that lower pan in the picture is one of those 'nice-to-have' truck pans with the removable clutch/flywheel cover, like this one. DD |
06-21-2020, 11:10 AM | #25 |
Got the full truck lash up,that drives me to the T5, figuring open driveshaft and 9" rear end
06-21-2020, 11:26 AM | #26 | |
You'll LOVE that T5, especially if you're CAREFUL about gear RATIO selection. Using the 'wrong' gear set can certainly mess-up an otherwise WONDERFUL and successful swap experience. It's too easy to assemble the 'perfect' combination with just a little research. DD |
06-21-2020, 01:14 PM | #27 |
Im hip on the ratio selection and admire the conversion you did.
06-21-2020, 01:20 PM | #28 | |
06-21-2020, 01:34 PM | #29 | |
Thank you....MUCH appreciated! DD |
06-21-2020, 01:44 PM | #30 |
Just my sugestion; before going bonkers, 55 gal drum put block in with lye caustic
some water fire wood light fire some "Jack" and "Bud" sit back till the steam comes out enjoy, cheap, nothing to lose, with some sticks mixed with charcoal brick'kets. Lots of heat is your friend. Pistons just may fall out. old saying "keep the fire burning" this is no joke It works and works for cheap. Then dissembled and pretty clean have it thermo clean'ed comes back pure cast iron: Note the Jack and Bud = women can see through concrete, well proven at my age LOL try it sam |
06-21-2020, 02:45 PM | #31 |
The lye solution will destroy your front and rear main seal retainers, I believe.
06-21-2020, 03:14 PM | #32 |
Betcha Mart could save that motor
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
06-21-2020, 04:27 PM | #33 |
Dont know Mart..Im a one trick pony,done this kind of crap for a living the last forty years and am that special kind of stupid that also does it for a hobby.
06-21-2020, 05:36 PM | #34 |
06-21-2020, 06:13 PM | #35 |
I just bust the pistons out with a 5X air hammer and a 401 chisel bit after using a small hole saw or large drill bit to start relieving some of the aluminum there. A person just has to be careful to stay away from the cylinder walls & con rods but they will break out pretty quick after you get used to it. Once a few big chunks break out, the piston & rod can easily be pulled out.
06-21-2020, 10:47 PM | #36 | |
GB
06-21-2020, 11:38 PM | #37 |
Budget build is my mantra..typical cheap ass ford owner..aint nothing cheap about a 34 coupe..
06-22-2020, 12:03 AM | #38 |
This method I saw online from some Aussie hillbilly. One rainy day I did two stuck blocks and kept 16 cylinders blazing for about 4 hours. I ran out of diesel fuel after a bit so started burning paint thinner mixed with marvel mystery oil. When that started running out I added brake fluid and carb cleaner mix and when that ran out I drank the last of the jack daniels and got all 16 pistons out with a 5 lb sledge and a roll of 2" wide lead flashing about 3" in diameter. Conformed beautifully to the piston's crown.
06-22-2020, 07:03 AM | #39 |
Looks like she fired up just fine GB
07-16-2020, 08:06 AM | #40 |
Right bank of the best 8BA,no cracks in the bad areas..some stud leakage but I figure sealing them will take care of it.On to the left side..The rusty 59AB's are still soaking,if nothing else they will become donors to convert the 8BA to center outlet heads and front distributor...I've heard that is possible,any side effects? |
