02-25-2018, 08:33 PM | #1 |
Rear corners fillers to support interior - missing
In both inside corners, there is a channel that goes around the corner. This channel, I believe, is what the interior is tacked into.
Much of mine is missing. What was the original material? What can I put into the channel that will accept the tacks and hold them tightly? Thanks, |
02-25-2018, 09:02 PM | #2 |
Re: Rear corners fillers to support interior - missing
check with an upholstery shop, they should have access to tack strip material.
02-25-2018, 10:19 PM | #3 |
I see you have installed Rattle Trap Sound Deadener in rear of your car. Did you do the whole car including the doors and floor? If so how big of a roll did you buy and was it enough?
02-26-2018, 03:03 AM | #4 |
Those metal channels are missing from my Tudor. Brattons sells the strip that mount in the metal channel, but not the channel.
www.brattons.com/catalogsearch/result/?q=29301 I have considered fabricating them from wood. |
02-26-2018, 06:53 AM | #5 |
I laminated 1/16" spruce strips purchased from a hobby shop in place - got glue all over myself and everything else and slide them in. You can go a little higher for more grip with a couple narrower strips.
John Last edited by aermotor; 02-26-2018 at 06:59 AM. |
02-26-2018, 01:35 PM | #6 |
02-26-2018, 01:54 PM | #7 |
Glue in a leveling strip, attach a strip of self adhesive VELCRO & attach a strip to the upholstery panel & you're DONE!
Bill Quick
