05-22-2018, 02:02 PM | #1 |
30 Tudor kick panel
I need a little help. I’m installing new kick panels. Check the photo attached is the panel in the right location? Or does go into the trough in front of where I have it. Yes I didn’t take enough pictures before starting this project.
Thanks |
05-22-2018, 02:05 PM | #2 |
Re: 30 Tudor kick panel
99% where you've got it is right.
Paul in CT Last edited by 1931 flamingo; 05-22-2018 at 05:01 PM. |
05-22-2018, 02:16 PM | #3 |
This is a picture Stew posted in another thread.
The picture I posted does not do you much good, it shows the part at the very bottom of your picture and you are asking about the part at the top. Bob Last edited by Bob C; 05-22-2018 at 09:27 PM. |
05-22-2018, 02:59 PM | #4 |
If your cardboard is bowing, it is pretty common to have to peel back the material, trim the board and glue the material back.
05-22-2018, 09:00 PM | #5 |
SORRY Mac101 you do not have the panel installed correct. you see the little grove in the toe board extension , the kick panel goes in that grove not on the back side the toe board extension.
05-23-2018, 06:02 AM | #6 |
05-23-2018, 06:42 AM | #7 |
[Bob C,
Beautiful interior! Did you do the wood? Bill W.[/B]
