Old 09-29-2015, 11:11 AM   #1
jdp8402
Default Rusty fuel tank.
I'm sure this has been covered hundreds of times on here but I can't get the search to work on my cell phone and I have time to kill while I'm waiting at the dentist office. What is good way to remove rust from inside the tank without removing it and damaging the paint? I thought about electrolysis but I read somewhere that the baffles won't allow it to work. I've also read about dumping in white vinegar or a molasses solution. My goal is to get as much out as I can for now just so I can drive it and see how everything is working. Eventually when I start to restore the car I'll have it boiled out.
Thanks,
Jeff
jdp8402 is offline   Reply With Quote
Old 09-29-2015, 11:49 AM   #2
FL&WVMIKE
FL&WVMIKE's Avatar
Default Re: Rusty fuel tank.
I read, on here, I think, to use acetone.
You fill your tank. Let it set for a while.
Drain it, through a hose, connected to your shut-off.
Strain it through a cloth and repeat.
Keep doing this until it comes out clear.
Be sure to put a filter on your gas line and watch it.
Vinegar might work, too. It is a weak acid and it would have to sit longer.
MIKE (MIKEBURCH)
FL&WVMIKE is offline   Reply With Quote
Old 09-29-2015, 12:54 PM   #3
Nathan_1929
Nathan_1929's Avatar
I've used the vinegar trick several times on vintage motorcycle and antique stationary engine gas tanks with great success. I'm never really in a hurry, so I can let them sit for days (or weeks?) at a time.
Works like a charm, but it'll rust again if you let it sit empty for a while. So, I try to put it back in service and fill it with gas ASAP.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic
Nathan_1929 is offline   Reply With Quote
Old 09-29-2015, 01:49 PM   #4
jdp8402
How big are the gas tanks on an A?
Old 09-29-2015, 01:58 PM   #5
Mitch//pa
evaporust
Old 09-29-2015, 02:11 PM   #6
jdp8402
I looked at evaporust at O'Reillys and that will get pretty pricey. The directions said to fill the tank clear up with it and it's $23 for a gallon. Does vinegar dissolve the rust or just break it loose from the metal?
Old 09-29-2015, 02:11 PM   #7
Mitch//pa
wasnt that one of the things you knew to check for a rusty tank
Old 09-29-2015, 02:12 PM   #8
Mitch//pa
evaporust is reusable for other projects
Old 09-29-2015, 02:16 PM   #9
jdp8402
Have you used evaporust? If so how were the results?
Old 09-29-2015, 02:17 PM   #10
DJ S
DJ S's Avatar
Yep!
DJ S is offline   Reply With Quote
Old 09-29-2015, 02:36 PM   #11
mrtexas
mrtexas's Avatar
There is generic evaporust out there by mail for 1/3 or less the price and are more concentrated as well. Works the same IMHO. I currently have some from rustdepot.com and it works out to $8.60 per gallon including shipping vs $25 per gallon for evaporust including tax and it is my second gallon from them. Since then I've found rust911.com and it is $3.72 per gallon. I'll buy that next. I bought several gallons of evaporust before I discovered the generic. The stuff will fix what others won't either. It fixed the stuck glove box hinge on my 36 Ford woodie for example.
Another advantage is you can mix it up more concentrated and it works faster. For $60 you can fill up your model A gas tank and have 6 gallons of concentrate left from rust911. Stuff works great and leaves no residue like phosphoric acid does. You clean the tank out to remove the dissolved rust and black residue which I assume is from the carbon in the rust that was dissolved.
mrtexas is offline   Reply With Quote
Old 09-29-2015, 02:49 PM   #12
Brentwood Bob
The attempts to clean the tank in vivo will be a good first project.
Look up dirty leg and install one.
Until you remove and have the tank boiled out you will need the dirty leg.
Bob
Brentwood Bob is online now   Reply With Quote
Old 09-29-2015, 03:03 PM   #13
Mitch//pa
i have used it with good results..
thats all i would consider using if i was doing the job,, i stick with success
Old 09-29-2015, 03:13 PM   #14
CarlG
CarlG's Avatar
More or less 10 Gallons. The later '31s had 11 gallons.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-29-2015, 03:45 PM   #15
Fullraceflathead
Fullraceflathead's Avatar
You could half fill the tank and carefully let it sit on each side for a few days then drain it.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-29-2015, 04:24 PM   #16
jdp8402
I think I'll give the evaporust a try. What all has to come apart to pull the gas tank off?
Old 09-29-2015, 05:18 PM   #17
jdp8402
Does anyoneare an aftermarket gas tank?
Old 09-29-2015, 05:37 PM   #18
Mitch//pa
does anyoneare an aftermarket gas tank?
nope
Old 09-29-2015, 05:37 PM   #19
DJ S
DJ S's Avatar
They do not make aftermarket gastanks... I'd imagine they would be trash if they made them anyhow.
Old 09-29-2015, 05:47 PM   #20
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I've got a tank in here right now that came in last Friday which was filled with some sort of "rust eater" (customer's word, -not mine) that he said didn't work. I suspect it worked just fine ...but the issue is, -even if it works really well and removes all of the rust from the inside metal, what do you suppose happens in a few days once the rust has been removed from the bare tank metal? I suspect it will be obvious to us as soon as we get the tank cut open! )
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
