10-10-2022, 11:13 AM | #1 |
Holey firewall, Batman!
The firewall on my '30 Town Sedan has acquired several extra holes over the years. I'm prepared to weld in some patches, but I thought I'd check with the braintrust to verify that what I believe are "extra" are really that. Please see the attached pictures, I believe #1-6 are non-standard and need to be filled.
There's also an extra hole in the dash panel that needs to be filled. Someone in the past really enjoyed drilling! Any thoughts? Thanks in advance. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
10-10-2022, 11:26 AM | #2 |
Re: Holey firewall, Batman!
All look like extras to me, just don't forget the vacuum hole but I think that is up by the tag.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
10-10-2022, 11:47 AM | #3 |
I think #6 is the speedometer cable, but I'm not with my car, so I can't check. Don't weld it up yet!
W. Michael |
10-10-2022, 11:49 AM | #4 | |
#6 is for the speedo cable.
Sorry not the best picture but the hole is in the red circle. Last edited by Y-Blockhead; 10-10-2022 at 12:36 PM. |
10-10-2022, 12:46 PM | #5 |
Good catch, w.michael and Y-B, I think you are correct about #6 being for the speedo cable. It's been a while since I took it apart and I forgot that. This is why I checked with you all! That would have been very embarrassing if I welded it up and then went to reassemble and couldn't figure out where the speedo cable goes...
Y-B: the hole is in the right side of the rail, close to the farthest right screw. Look at #8 in this post to see a picture. Looks like it's pretty similar to the one you have. JayJay
10-10-2022, 01:03 PM | #6 |
The hole in the dash rail was probably drilled there for a cigarette lighter, although these were usually mounted closer to the driver's side. Marshall |
10-10-2022, 01:09 PM | #7 | |
JayJay
10-10-2022, 01:36 PM | #8 | |
The one Marshal is referring to is directly above the exhaust manifold and does have a d-nut on it. Last edited by Y-Blockhead; 10-10-2022 at 05:06 PM. |
10-10-2022, 04:36 PM | #9 |
It looks like a coolant heater was installed at some time. Most of the holes I find are for the exhaust manifold type heaters. The usually have one large hole for the carri through and multiple small holes to hold it on.
10-10-2022, 06:56 PM | #10 | |
In any event, here are updated labels. I'm going to go with filling holes #1-5. Thanks all for your input. JayJay
10-10-2022, 08:41 PM | #11 |
Jay-Jay is correct about #3. I was too far to the left - which no one has EVER accused me of being before!
Marshall |
10-11-2022, 11:57 AM | #12 | |
But thanks for your input, all of this helped me rethink everything and assure myself I was doing the correct thing. JayJay
10-11-2022, 12:40 PM | #13 |
We were all likely basing our input on the photos you posted, which show the firewall facing the viewer. Hence my "left" orientation. No matter, though. You've gotten the holes identified that can stay and those that should be closed up. You'll need to cut sheet metal circles to plug those larger presumably heater hose holes, followed by welding into place. The small holes could possibly be filled by welding or brazing them shut and then grinding them smooth. If you do weld, be sure the gas tank is isolated by a sheet metal panel or some kind of heat sink so that the tank doesn't get hot - with unfortunate results.
Marshall Last edited by Marshall V. Daut; 10-11-2022 at 03:55 PM. |
10-11-2022, 01:38 PM | #14 | |
I plan to remove the gas tank before doing the welding. I need to pull it out to clean up the inside anyhow. JayJay
10-11-2022, 05:51 PM | #15 |
Don't drill any extra holes in the gas tank.
10-11-2022, 08:23 PM | #16 |
Saw one posted here years ago, it had a bazillion holes drilled on the drivers side so they could mount a speaker on the engine side. LOL
10-12-2022, 10:10 AM | #17 | |
Amazing! I have a roadster that has the same problem- maybe 80 holes drilled in a grid pattern above the steering column. For years I thought that the prior owner wanted to get more engine heat into the cab. I finally started to re-restore it this spring, and when I took the kick panels off I saw two holes that had been drilled that looked like they may have been used to mount an aerial on the side of the cowl panel. Then when I took a close look at the seat riser, I saw holes that may have been used to mount a radio under the seat. It was then that I realized that the 80 holes in the firewall were a speaker grill! I have maybe 20 other extra holes that have been drilled in over the years- too many and too big to fill. I bought a good used firewall at Hershey a few years ago. I drilled out the rivets and spot welds and am in the process of installing the new firewall. |
