Old 03-20-2020, 02:03 PM   #1
Twrench~70
Default 1938 Ford standard clutch assy.
guys, I was wondering if it's possible to change a clutch for a 60hp motor that comes with a 8.5 clutch to a 9 inch clutch and pressure plate assembly. this one is giving me fits as to what to do. Any suggestion would help or am I doomed to stay with the 8.5 clutch and pressure plate. thank you
Twrench~70 is offline   Reply With Quote
Old 03-20-2020, 02:06 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 1938 Ford standard clutch assy.
Only if you find a 40 flywheel and transmission
What's the problem you are having?
Old 03-20-2020, 05:07 PM   #3
Twrench~70
parts availability thats all. I can get it fixed but its way too costly. thank you for the reply Kurt.
Old 03-20-2020, 08:14 PM   #4
Brian
Brian's Avatar
I 'think' early Jeeps run an 8 1/2" Auburn pressure plate. Could you possibly adapt one of those in? i run Auburn clutches on my motors [not Jeep though], and love them!
Old 03-21-2020, 08:09 AM   #5
Gary in La.
Gary in La.'s Avatar
Be advised that the 60 HP clutch and trans have a smaller diameter splined input shaft than the full size combo.
Gary in La. is offline   Reply With Quote
Old 03-21-2020, 01:12 PM   #6
Brian
Brian's Avatar
Fort Wayne Clutch?
