09-24-2013, 02:29 PM | #1 |
Gonna drive every day
Hi, I live in the north east. Is there a good or preferred way to have heat in the cab of my pickup? I'm thinking about a 12 volt battery in a box in the bed and a ceramic heater? Appreciate the help Gino
09-24-2013, 02:39 PM | #2 |
Re: Gonna drive every day
I'd suggest you find an Otwell Health Heater, which replaces the exhaust manifold. I'm very pleased with mine, especially since I live up near Lake Superior!
09-24-2013, 02:49 PM | #3 |
I put a hot water heater in mine. Wife loves it!
09-24-2013, 02:52 PM | #4 |
If it will fit in the cab, a Southwind Heater will do the job. But I don't know if it will fit.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
09-24-2013, 03:04 PM | #5 |
Get an old Autolite manifold heater and do the install. You may already have "the hole" cut thru your firewall. Many do.
09-24-2013, 03:30 PM | #6 |
09-24-2013, 03:33 PM | #7 |
That's what I did.
09-24-2013, 03:48 PM | #8 |
I have used a small coleman catalytic heater and it will definitely keep you warm and with the volume of air leaks in the A, no O2 concerns.
Gene USN |
09-24-2013, 03:53 PM | #9 |
09-24-2013, 03:55 PM | #10 |
Resistance heat from a 12 volt battery will drain the battery very quickly, so it isn't really practical.
09-24-2013, 03:56 PM | #11 |
Do you happen to have a photo of that "hole". I have a hole in the firewall of my '28 roadster and have always wondered what it was for. I looks factory and has always baffled me.
09-24-2013, 04:20 PM | #12 |
Using electricity to generate heat always requires a lot of current. I would go with the hot water heater.
Charlie Stephens |
09-24-2013, 08:04 PM | #13 |
PeteCruz, I don't have a photo yet of my manifold heater door hole, but it is a very LARGE one in the firewall, just above and in-line with your exhaust manifold. About 2-1/4" diam. Up here in the Northeast, I can count on one hand, how many A's I've seen that DON'T have that heater door hole. That's restored ones, "woods finds" and everything car in between. I like the idea of a water heater, but the "A" has such limited room up front for the heater core and a real pain to remove the floorboards sometimes if all the floor screws are in place.
09-24-2013, 08:15 PM | #14 |
Here's one off Google
09-24-2013, 10:12 PM | #15 |
yea hole is about the size of 2 1/4 exhaust tubing could slide thru it...
09-24-2013, 10:13 PM | #16 |
see the baseball sized hole in the lower firewall section? (yes its whats left of my cab....)
09-26-2013, 07:01 AM | #17 |
Ok, I like the idea of a hot water heater. If anyone can give me some info on the brand of heater and how to do it I'd be grateful, thanks Gino
09-26-2013, 07:40 AM | #18 |
My vote is water heater. If you choose the exhaust manifold heater you'll smell like the engine compartment. Hot water heaters aren't hard to install. Just a little piping and mounting the box inside.
Cowtown A's |
09-26-2013, 08:49 AM | #19 | |
I've also been thinking about just wrapping the muffler and using that heat through a floor grate. That would be even easier as I won't have to run hoses and change the water fittings. |
09-26-2013, 09:13 AM | #20 |
Do you have 12v or 6? If you have 12 there are a number of heater for closed cab farm tractors etc. Here are a couple of options.
http://item.mobileweb.ebay.com/viewi...d=350655925187
