04-17-2013, 02:57 AM | #1 |
Speedo Gear Drive Exchange
Have changed out a 21 tooth unit,turtle, with a 19 tooth unit turtle to raise speedo mph readings. Too low.
Can an 18 tooth gear be exchanged into to 19 tooth housing? Or do I require an 18 tooth housing? Thanks, Phil NZ |
04-17-2013, 05:14 AM | #2 |
Re: Speedo Gear Drive Exchange
Although the 18t housing would have the "18" mark on it, I believe the two housings are the same size inside and out.
04-17-2013, 06:08 AM | #3 |
