Old 04-16-2013, 08:38 AM   #1
32phil
Default 40 pick up fenders
For all the 40 guys out there....Will 40 passenger front fenders fit a 40-41 pick up ? What modifications will be necessary to make them work?
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 04-16-2013, 09:30 AM   #2
DICK SPADARO
Default Re: 40 pick up fenders
Yes and No, technically they are different fenders the PU is actually narrower. The area where the fender bolts to the cowl is different on a pick up than a passenger car so they have different flange mountings. Can yo put a passenger car fender on a PU well yes but requires big hammer.
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 04-16-2013, 10:03 AM   #3
skidmarks
skidmarks's Avatar
More like a pair of flanging pliers will make them fit and not a big hammer. Were the fender meets the side of the cowl needs folded over alittle more. Not much
You also need to fit them a little were it bolts to the running board and drill a couple holes. You need the small fender to cowl bracet that you can get new.
For a restoration you will get a hard time. For a hotrod make them work. I have on a few I have built
skidmarks is offline   Reply With Quote
