Old 01-27-2019, 10:05 AM   #1
russcc
Default Help removing a stuck woodruff key.
A woodruff key partially sheared off in a shaft on the lathe. Tried tapping it out, and heat, no go. Any ideas ? Thank you Fordbarners.
Old 01-27-2019, 10:48 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Help removing a stuck woodruff key.
If it is truly a Woodruff key then hitting it on either end toward the center of the shaft should rotate it out.
As in this Vid.----
https://www.youtube.com/watch?v=vJoXfIPQQtE
Old 01-27-2019, 10:55 AM   #3
19Fordy
19Fordy's Avatar
A photo is worth a 1000 woodruff keys. If there is sufficient room to work with a Dremel tool, cut the key out with a small Dremel cut off wheel being careful to not go oversize.
Constantly test fit with another replacement key.
However, the first thing you should do is consult with Mr. Google.
https://www.google.com/search?q=ho+t...hrome&ie=UTF-8
Old 01-27-2019, 11:01 AM   #4
rotorwrench
rotorwrench's Avatar
You may have luck with a properly sized cape chisel. Get one that is more narrow than the width of the woodruff key or grind one to the proper width and start working it at one end or the other to make a divot for other punches to seat on if the chisel doesn't get it to move. Flat keys on a straight or tapered shaft have to slide out but a round bottom woodruff key has to rotate out. When it moves, it should come out. If that doesn't work then a dremel or other rotary grinder type tool may have to be used to grind it thin & peel it out.
Old 01-27-2019, 11:05 AM   #5
big job
big job's Avatar
Be patient it didn't grow in there
big job is offline   Reply With Quote
Old 01-27-2019, 12:57 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
I used autobody dent puller pin welder, then slidehammer
Old 01-27-2019, 01:09 PM   #7
cobbie
I agree with 51 MERC-CT . Just be careful and take your time.
cobbie is offline   Reply With Quote
Old 01-28-2019, 01:31 PM   #8
russcc
Thank you. As always, be patient, I didn't grow there, and be careful with the Dremel tool with the cutoff wheel. Got it.
Old 01-28-2019, 02:59 PM   #9
Tim Ayers
A little heat should help
Old 01-30-2019, 10:13 PM   #10
Bubsyouruncle
Do not use a grinder!
Any tapping or pounding processes will not harm the surfaces.
grinding will!
be patient.
you will sucked.
Bubsyouruncle is offline   Reply With Quote
