Old 04-24-2015, 07:56 AM   #1
steamgas
steamgas's Avatar
Default 1932 v-8 motor
what should i look for to identify a true 1932 v-8 ford motor? motor number,piston size.etc
steamgas is offline   Reply With Quote
Old 04-24-2015, 08:11 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 1932 v-8 motor
Very easy , it is the only flathead ford that the water drain petcocks in the front side of the block point straight down . All other flatheads they are angled out from the block. Also the front of the block between water outlets & timing cover is flat with no indentations or cavitys. There are many other differences but these two make it so easy to identify. Look for the thread I have started as in the near future I hope to have pictures on it as I reassemble this engine getting it ready to sell.
Cheers
Tony
Old 04-24-2015, 08:30 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Information + pictures available in this post...
https://www.fordbarn.com/forum/showthread.php?t=25301
John
