08-11-2021, 09:13 PM | #1 |
Original motor value
Just curious. Would a Model A with the original motor be valued higher than a replacement or restamped motor? Also would a replacement or restamped motor give you pause not to buy the car?
Thanks for your opinion Charley |
08-11-2021, 09:20 PM | #2 |
Re: Original motor value
It might depend on how well either engine ran. Not many model As made it this long wearing its original engine. On most As the body would have to be lifted just to verify the fact.
08-11-2021, 09:27 PM | #3 |
I place more value on matching original numbers, but the most important thing is how well it runs.
08-11-2021, 09:47 PM | #4 |
As J Franklin says, it can be impossible to verify that the numbers match without disassembling the car, so as the buyer, sometimes the only thing you can do is look for whether the manufacturing date of the engine is roughly correlated to the apparent "model year" of the body.
08-12-2021, 03:03 AM | #5 |
to most- it doesnt matter for a driver. to those that it matters, can be a 10% differential.
just resell to someone where it doesnt matter............90% of the crowd. what is important is that the engine runs well. |
08-12-2021, 06:21 AM | #6 |
the number is just easier to correct than a poor runner.....
our next Model A is out there in the unknown...... |
08-12-2021, 06:26 AM | #7 |
6 or 7 figure model A, then yes, now where's at stainless steel Tudor ?
08-12-2021, 06:31 AM | #8 |
I would think matching numbers become more important as the value of the car increases. A driver that isn't very original with 12V alternator, juice brakes, over drive, etc etc won't matter so much if the numbers don't match. A pristine 2 door completely stock Phaeton would likely matter more.
My numbers match, but I can't find the photo I took of the frame number... sigh. |
08-12-2021, 07:04 AM | #9 |
As a potential Model A buyer, I would def. be more excited about buying a car that had the original motor. However, after reading this forum for a few years I have realized that there have been many cars with replacement motors even dating back to the factory service replacements. Buying a car with a replacement would in no way break the deal, original would only make it that much better. ASSUMING the original motor is indeed road worthy and serviceable.
08-12-2021, 07:07 AM | #10 |
consider your audience- half would be rodders that would pull the motor anyway for a sbc.
08-12-2021, 08:04 AM | #11 |
If it has the original engine, it means not too many things were messed with (theoretically).
"The more things change, the more they stay the same." |
08-12-2021, 08:10 AM | #12 |
Ford had an a engine replacement program even then, offered V8 engine replacement in 1933 for the 32 Fords that were hardly a year old! Dealer was to restamp replacement engine with original number, so say a 1929 had a engine change in 1931 by the dealer, by now everyone would think it’s the original.however the are differences on later engine. Unless you are building a points car , a good running engine would be more important.As I mentioned many engines were changed out early in Model A s career.
08-13-2021, 07:24 AM | #13 |
matching number does not guarantee original engine.
I have re-stamped 2 replacement engines to match titles......
08-13-2021, 07:37 AM | #14 |
08-13-2021, 08:06 AM | #15 |
08-13-2021, 08:30 AM | #16 |
Not to hijack my own post but I have a question?
Next to JD-OHIO post a green dot was shown next to the report button. Did I do something accidently while scrolling to cause that green light? Backed out and then looked at the post again and the dot on his post clear like all the other replies. Apologize to JD-OHIO if I accidentally reported your post. I am left handed so scroll with same. |
08-15-2021, 03:53 PM | #17 | |
No green dot, then they must be in the garage working on their Model A. |
08-13-2021, 09:05 AM | #18 |
Hello again, I think the reason the restamp numbers are on a ground surface is because that is how the old number was removed. In Pennsylvania it would have been illegal to have an engine without numbers.Car thieves were as prevalent then as now , that is how “Baby Face Nelson “ got his start. Engine number always starts and ends with a star and the font was somewhat particular to Ford also changed in 1931 .
08-13-2021, 09:12 AM | #19 |
gdmn
Tom is referring to the rough casting on the block. replacement blocks would have had rough castings. a ground block is too smooth and obvious........... of course, we are mostly speaking of common A's and not a Van Gogh here. how "real" do you want your forgery to be? all is possible. look up the henning nickel- he almost had it right........ many cars get their senior awards at Hershey, with some small amount of "forgery" involved- esp the brass cars. |
08-14-2021, 08:58 AM | #20 |
no forgery involved, ronn.
just replacement of a worn out or damaged part (engine block) with another that matches it exactly (including number).....
